LOS light is red on ONT
Ij78
Been on Fibre 900 for one week. All good until today when I got a red LOS light in OpenReach ONT.
Checked all cables in and out and reset ONT. Raised a ticket with PlusNet but no engineer available for three days, so no internet until then.
Feel sad that I left old provider now but any advice of things to do / try ?
2 REPLIES 2
Fixes: 530
Re: LOS light is red on ONT
@Ij78 there's nothing that YOU can do. LOS indicates a fault on the external network, it will need OR to investigate and fix.
willcutforth
Fixes: 113
@Ij78 sorry to hear you are having issues, I'm going to send you a PM to get your username and then I will test everything for you.
 Will Cutforth
