LOS Red Light
eglevienasdu
LOS Red Light
Can't find a way to delete the post..
1 REPLY 1
Fixes: 387
Re: LOS Red Light
@eglevienasdu A red LOS  light, in your case, indicates an Openreach circuit fault, which typically be rectified remotely. When did you report it?
