Is plusnet down?
conorr1888
Is plusnet down?
My broadband connection has just stopped working anyone else having the same issue?
7 REPLIES 7
Fixes: 388
Re: Is plusnet down?
@conorr1888 Highly unlikely to be a major issue, otherwise yo would see lots of posts along the same lines. 😉
When you say 'it's stopped working' what exactly do you mean?
stevenh78
Yeh mines went down before 7pm still waiting for it to get fixed, logged a ticket says problem not to do with my bit so engineer need to check.
Fixes: 388
@stevenh78 Not necessarily the same issue though - PN have a lot of customers all over the country, and faults can develop anywhere.
conorr1888
Hi there, well I was playing my playstation and the Internet disconnected and has been disconnected for over 2 hours
conorr1888
Mine went down roughly the same time as you
Fixes: 388
@conorr1888 'Went down' - in what way? What colour lights are on your Hub?  Are you back up?
stevenh78
They resolved the issue around midnight and was able to connect again.
May have been authentication server or backbone issue as DSL had been up but just timing out when it was trying to get the internet link.
