Internet dropping out
- Full Fibre
- Internet dropping out
- « Previous
- 1
- 2
- Next »
Re: Internet dropping out
23-12-2021 9:14 PM
All due respect but I'm not "new" to wifi/internet issues. I have a third party router as it gave me better wifi coverage than the plusnet one (I also had a modified plusnet one which was sent out to me last time I had connection issues), my router is up high in the centre of my house away from all other electronic devices, I have it set to auto select wifi channel including 12 and 13 and it uses both 2.4ghz and 5ghz, firmware is all up to date also.
I understand you may be pointing towards wifi but that alone doesn't explain the network dropping, that is an ISP/Line issue as even if my devices were connected via rj45 cable then they would still be disconnected due to the network loss.
Apologies if this sounds rude, it really wasn't meant to!
23-12-2021 9:29 PM - edited 23-12-2021 9:30 PM
No problem, from the graph in the last 10 days your broadband has dropped mainly overnight and once Monday night with no drops in the last 2 days. Are you seeing your devices drop more times than this?
If that answer’s no, then it’s hard to mount an investigation, because unless our testing shows a fault, our suppliers consider an intermittent connection to be 3 drops within the last 24 hours or 6 drops within 72 hours.
If the answer’s yes though, I’d say that the additional drops are more closer to home as neither your router logs or our logs show drops outside of those times (not counting the drop you’ve had this afternoon showing in your router’s log after I posted the graph of your connection)
Do you have a laptop you can plug into the router using a cable you can check when your wireless device next drops out (and your router log doesn’t show a DSL or PPP drop)? That’ll help to get to the bottom of things. ![]()
23-12-2021 9:47 PM
23-12-2021 9:52 PM
Ah OK no problem, makes sense. ![]()
I’d keep an eye on things because your download speed is artificially restricted and that should be sorted over the next few days, perhaps into next week due to Christmas, as there’s normally an underlying issue behind that.
23-12-2021 10:25 PM
Thank you for your time
23-12-2021 10:39 PM
Cool. No problem. Merry Christmas ![]()
- « Previous
- 1
- 2
- Next »
