Intermittent Broadband
Dudgers
All day my broadband has been dropping..
Bt homehub light stays blue...
Can someone look into this please
24 REPLIES 24
Fixes: 1,662
Re: Intermittent Broadband
Thanks for your post @Dudgers
I'm really sorry to see your connection's dropping.
I've tested your line and the tests aren't showing any issues. If the light on your router stays blue then this suggests the broadband signal to your router isn't dropping and the problem may be a little closer to home.
Are your devices connecting to your router wirelessly or wired into it using an ethernet cable?
digg3r
Try rebooting your router and checking all cables are securely connected and have no damage or general wear and tear, Sounds like its a hardware communication issue rather than a connection issue.
Dudgers
Thanks for the reply
router is connected by ethernet,so i assumed there was an issue with the router so i changed it to the technicolor 582n.Logged in etc and it just wouldnt connect to the internet..i also tried a homehub 4 and that wouldnt connect..
any ideas what to do next?
Dudgers
Forgot to say that i put my original router back on and connected fine but still dropping etc @Gandalf
Fixes: 1,662
Thanks for getting back to me @Dudgers
I suspect the other routers you've tried may not have been compatible for fibre broadband.
What do the logs show in your router we've sent? You can find the logs by going to your router's settings at http://192.168.1.254, then navigate to the Troubleshooting > Helpdesk tabs. Feel free to copy & paste them here.
Dudgers
So bought a new router..homehub 6 and its worked fine but today im back to square one and its doing it again...any suggestions?
@Gandalf
Fixes: 243
"All day my broadband has been dropping.. Bt homehub light stays blue..."
Please describe in detail what you are doing when you perceive things are not working and the state of the router.
If the router lights are blue, then it is connected to the internet ... but there are a lot of other things which might not be right.  You mention the TG582n - there are specific issues with that router with Win8/8.1/10 (IP address spoofing) and I have no reason to believe that Win11 is not impacted the same.  The issue manifests as web browsers reporting no internet connection when you are in fact connected.  I have seen separate browser tabs concurrently report connected ... and not connected.
Are the devices WiFi connected?
Can you access the router user interface in this condition? http://192.168.1.254
Does this impact BOTH WiFi and wired connected devices at the same time ... or just WiFi devices?
Is there noise on the telephone when this happens?
Is there anything in the router log around the time of the issue?
@Gandalf advises that there is no line fault and no evidence of disconnections, so you are probably looking at a PC issue, a Wi-Fi issue or interference on the line sufficient to interrupt data transmission, but not enough to drop line sync.
SammyM
Fixes: 101
Hiya @Dudgers,
I'm sorry to hear that the issue is still ongoing, even with a new router and I would like to see what is happening to the connection from your side.
Can you drop us over the router logs as @Gandalf has suggested so I can see the drops as it registered on the router itself.
 Sammy M - Sheffield Team
Fixes: 243
"interference on the line sufficient to interrupt data transmission, but not enough to drop line sync"
Broadband is not going to work well if the "phone" line is not working properly.
Please perform a quiet line test - dial 17070 select option 2 using a corded phone plugged into the test socket behind the face plate of the master socket. It should be silent. A noisy phone line (or no dial tone) will have a marked adverse impact on the performance of broadband.
If the line is noisy or there is no dial tone, then a PHONE LINE fault needs to be raised with your phone provider. If this is PlusNet, you can report a fault on line using the button below.  From the Q&A list, choose the one which matches the problem, 'open' the 'section' and click the trouble-shooter link.  NB: If you receive a failure message (rather than a log-in prompt) then log-in to the user portal in a different browser tab and attempt to use the trouble-shooter again.
Dudgers
@SammyM
This?
15:58:50, 04 Mar.
:This Rule has been applied successfully: [id:4372, InternalClient: 192.168.1.66, External Ports:(9000,0), Internal Ports: (9000,0), Protocol: TCP]
15:58:50, 04 Mar.
:Adding port mapping rule by System
15:58:50, 04 Mar.
:Updating port mapping rule (4372) by System
15:58:47, 04 Mar.
:HTTP UserBasic login from 192.168.1.78 successfully
15:58:00, 04 Mar.
eth3:[Device Connected] MAC Address:18:31:bf:b6:fb:cd Host Name: DESKTOP-N7V3KT1 IP Address: 192.168.1.78, lease duration is 86400 seconds.
15:58:00, 04 Mar.
BR_LAN:The DHCP options that are offered by the device (id:4): DiscoverOptions: | DiscoverOption55: | RequestOptions: 53,61,50,12,81,60,55 | RequestOption55: 1,3,6,15,31,33,43,44,46,47,119,121,249,252 | HostName: DESKTOP-N7V3KT1 | VendorId: MSFT 5.0
15:58:00, 04 Mar.
:DHCP Confirmation of Request
00:03:13, 01 Jan.
ppp1:TR69 connectivity to (pbthdm.bt.mo) has been closed
00:03:12, 01 Jan.
ppp1:TR69 connectivity to (pbthdm.bt.mo) has been initiated
00:03:12, 01 Jan.
ppp1:TR69 receiving InformResponse message
00:03:12, 01 Jan.
ppp1:TR69 event found : 4 VALUE CHANGE
00:03:12, 01 Jan.
ppp1:TR69 event found : 1 BOOT
00:03:12, 01 Jan.
ppp1:TR69 sending Inform message
00:03:11, 01 Jan.
00:03:11, 01 Jan.
00:03:11, 01 Jan.
00:03:10, 01 Jan.
ppp1:TR69 creating new session with ACS
00:03:06, 01 Jan.
BR_LAN:UPnP functionality has been activated
00:03:06, 01 Jan.
BR_LAN:UPnP functionality has been deactivated (manually)
00:03:06, 01 Jan.
:Deleting port mapping rule (4371) by System
00:03:06, 01 Jan.
:Updating port mapping rule (4371) by System
00:03:05, 01 Jan.
:WAN: SENSING AUTO VDSL
00:03:05, 01 Jan.
ppp1:New DYN ROUTE is added [212.159.6.10/32 gw 172.16.14.77]
00:03:05, 01 Jan.
ppp1:New DYN ROUTE is added [212.159.6.9/32 gw 172.16.14.77]
00:03:05, 01 Jan.
ppp1:PPP: PPP INFO 212.159.6.9,212.159.6.10
00:03:05, 01 Jan.
ppp:PPP: IPCP_NAK
00:03:05, 01 Jan.
ppp:PPP: CHAP_SUCCESS
00:03:05, 01 Jan.
ppp:PPP: CHAP_RESPONSE
00:03:05, 01 Jan.
ppp:PPP: LCP_GOOD_ACK
00:03:05, 01 Jan.
ppp:PPP: LCP_REQUEST
00:03:04, 01 Jan.
:PPPoE error: timeout
00:03:03, 01 Jan.
BR_LAN:The DHCP options that are offered by the device (id:7): DiscoverOptions: | DiscoverOption55: | RequestOptions: 53,61,50,57,60,12,55 | RequestOption55: 1,33,3,6,15,28,51,58,59 | HostName: android-b6404a86d6c82d56 | VendorId: dhcpcd-5.5.6
00:03:03, 01 Jan.
00:03:02, 01 Jan.
wl1:A WiFi device <AC:EE:9E:23:B1:A9> has successfully connected to SSID (Device/WiFi/SSIDs/SSID[WL_PRIV2G])
00:02:48, 01 Jan.
00:02:40, 01 Jan.
00:02:36, 01 Jan.
00:02:30, 01 Jan.
ptm0.101:VLAN VLAN_DATA connected
00:02:29, 01 Jan.
:connection ATM_TV disconnected.[ERROR_USER_DISCONNECT]
00:02:29, 01 Jan.
:connection ATM_DATA disconnected.[ERROR_USER_DISCONNECT]
00:02:29, 01 Jan.
dsl:VDSL link Up: Down Rate=32818Kbps, Up Rate=4925Kbps, SNR Margin Down=0.00dB, SNR Margin Up=3.00dB
00:02:15, 01 Jan.
BR_LAN:The DHCP options that are offered by the device (id:8): DiscoverOptions: | DiscoverOption55: | RequestOptions: 53,55,57,61,50,51 | RequestOption55: 1,121,3,6,15,108,114,119,252 | HostName: | VendorId:
00:02:15, 01 Jan.
00:02:15, 01 Jan.
wl0:A WiFi device <3E:A4:C9:4A:08:45> has successfully connected to SSID (Device/WiFi/SSIDs/SSID[WL_PRIV5G])
00:02:09, 01 Jan.
:This Rule has been applied successfully: [id:4371, InternalClient: 192.168.1.66, External Ports:(9000,0), Internal Ports: (9000,0), Protocol: TCP]
00:02:09, 01 Jan.
00:02:09, 01 Jan.
00:01:11, 01 Jan.
:HTTP UserBasic login from 192.168.1.81 successfully
00:01:11, 01 Jan.
00:01:09, 01 Jan.
wl1:(11/1) Channel Hopping initiated/Manually initiated
00:00:51, 01 Jan.
00:00:49, 01 Jan.
eth3:An Ethernet port is now connected (4/1000/FULL)
00:00:49, 01 Jan.
eth2:An Ethernet port is now connected (3/1000/FULL)
00:00:49, 01 Jan.
eth1:An Ethernet port is now connected (2/1000/FULL)
00:00:41, 01 Jan.
:This Rule has been applied successfully: [id:1, InternalClient: , External Ports:(0,0), Internal Ports: (0,0), Protocol: ]
00:00:41, 01 Jan.
:Updating port mapping rule (1) by UPnP
00:00:40, 01 Jan.
BR_LAN:The LAN DHCPv6 Server is active
00:00:40, 01 Jan.
:The LAN DHCP Server is active
00:00:39, 01 Jan.
BR_LAN: Allocated prefix = fdaa:bbcc:ddee::/64 (valid time = 4293967296 / preferred time = 4293967296)
00:00:39, 01 Jan.
:DNS name resolution is now active
00:00:39, 01 Jan.
wl0:WLAN has been deactivated (BTWifi-X) (band : 5GHz).
00:00:39, 01 Jan.
wl0:WLAN has been deactivated (BTWifi-with-FON) (band : 5GHz).
00:00:39, 01 Jan.
wl0:WLAN has been activated (BTHub6-W7X9) (band : 5GHz).
00:00:39, 01 Jan.
wl1:WLAN has been deactivated (BTWifi-X) (band : 2.4GHz).
00:00:39, 01 Jan.
wl1:WLAN has been deactivated (BTWifi-with-FON) (band : 2.4GHz).
00:00:39, 01 Jan.
wl1:WLAN has been activated (BTHub6-W7X9) (band : 2.4GHz).
00:00:37, 01 Jan.
wl0:(0/36) Channel Hopping initiated/Manually initiated
00:00:36, 01 Jan.
wl1:(0/11) Channel Hopping initiated/Manually initiated
00:00:36, 01 Jan.
:FIREWALL --INPUT_DROP--IN=eth1 OUT= MAC=ff:ff:ff:ff:ff:ff:70:85:c2:f0:2f:c9:08:00 src=0.0.0.0 DST=255.255.255.255 LEN=328 TOS=0x00 PREC=0x00 TTL=128 ID=24177 PROTO=UDP SPT=68 DPT=67 LEN=308
00:00:36, 01 Jan.
:FIREWALL --INPUT_DROP--IN=eth2 OUT= MAC=ff:ff:ff:ff:ff:ff:ec:71:db:ea:79:47:08:00 src=192.168.1.66 DST=255.255.255.255 LEN=576 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=UDP SPT=68 DPT=67 LEN=556
00:00:36, 01 Jan.
:FIREWALL --INPUT_DROP--IN=eth1 OUT= MAC=ff:ff:ff:ff:ff:ff:70:85:c2:f0:2f:c9:08:00 src=0.0.0.0 DST=255.255.255.255 LEN=328 TOS=0x00 PREC=0x00 TTL=128 ID=24176 PROTO=UDP SPT=68 DPT=67 LEN=308
00:00:36, 01 Jan.
:FIREWALL --OUTPUT_DROP--IN= OUT=bcmsw src=0000:0000:0000:0000:0000:0000:0000:0000 DST=ff02:0000:0000:0000:0000:0000:0000:0016 LEN=76 TC=0 HOPLIMIT=1 FLOWLBL=0 PROTO=ICMPv6 TYPE=143 CODE=0
00:00:36, 01 Jan.
:FIREWALL --INPUT_DROP--IN=eth1 OUT= MAC=ff:ff:ff:ff:ff:ff:70:85:c2:f0:2f:c9:08:00 src=0.0.0.0 DST=255.255.255.255 LEN=328 TOS=0x00 PREC=0x00 TTL=128 ID=24175 PROTO=UDP SPT=68 DPT=67 LEN=308
00:00:36, 01 Jan.
00:00:36, 01 Jan.
:FIREWALL --INPUT_DROP--IN=eth1 OUT= MAC=ff:ff:ff:ff:ff:ff:70:85:c2:f0:2f:c9:08:00 src=0.0.0.0 DST=255.255.255.255 LEN=328 TOS=0x00 PREC=0x00 TTL=128 ID=24174 PROTO=UDP SPT=68 DPT=67 LEN=308
00:00:36, 01 Jan.
:The Modem has successfully powered up
00:00:36, 01 Jan.
:WDG Laststatus:: # Current boot was caused by Power Reset
00:00:24, 01 Jan.
:WAN: ethernet as WAN
15:48:19, 04 Mar.
:This Rule has been applied successfully: [id:4426, InternalClient: 192.168.1.66, External Ports:(9000,0), Internal Ports: (9000,0), Protocol: TCP]
15:48:19, 04 Mar.
15:48:19, 04 Mar.
:Updating port mapping rule (4426) by System
15:48:19, 04 Mar.
:Deleting port mapping rule (4425) by System
15:48:19, 04 Mar.
:Updating port mapping rule (4425) by System
15:47:32, 04 Mar.
eth1:[Device Connected] MAC Address:70:85:c2:f0:2f:c9 Host Name: DESKTOP-O45DHM2 IP Address: 192.168.1.81, lease duration is 86400 seconds.
15:47:32, 04 Mar.
BR_LAN:The DHCP options that are offered by the device (id:6): DiscoverOptions: | DiscoverOption55: | RequestOptions: 53,61,50,12,81,60,55 | RequestOption55: 1,3,6,15,31,33,43,44,46,47,119,121,249,252 | HostName: DESKTOP-O45DHM2 | VendorId: MSFT 5.0
15:47:32, 04 Mar.
15:47:25, 04 Mar.
15:47:22, 04 Mar.
eth1:A device has been disconnected from an Ethernet port (2)
15:47:07, 04 Mar.
15:43:03, 04 Mar.
:This Rule has been applied successfully: [id:4425, InternalClient: 192.168.1.66, External Ports:(9000,0), Internal Ports: (9000,0), Protocol: TCP]
15:43:03, 04 Mar.
15:43:03, 04 Mar.
15:43:03, 04 Mar.
:Deleting port mapping rule (4424) by System
Dudgers
@Townman
Phone line quiet test was all good...
Dudgers
@SammyM
16:04:05, 04 Mar.
:This Rule has been applied successfully: [id:4373, InternalClient: 192.168.1.66, External Ports:(9000,0), Internal Ports: (9000,0), Protocol: TCP]
16:04:05, 04 Mar.
16:04:05, 04 Mar.
:Updating port mapping rule (4373) by System
16:04:05, 04 Mar.
:Deleting port mapping rule (4372) by System
16:04:05, 04 Mar.
16:02:51, 04 Mar.
BR_LAN:The DHCP options that are offered by the device (id:5): DiscoverOptions: | DiscoverOption55: | RequestOptions: 53,61,50,57,60,12,55 | RequestOption55: 1,3,6,15,26,28,51,58,59,43,114,108 | HostName: Paul | VendorId: android-dhcp-12
16:02:51, 04 Mar.
16:02:51, 04 Mar.
wl1:A WiFi device <DA:07:60:01:FE:12> has successfully connected to SSID (Device/WiFi/SSIDs/SSID[WL_PRIV2G])
16:02:49, 04 Mar.
BR_LAN:The DHCP options that are offered by the device (id:7): DiscoverOptions: 53,61,57,60,12,55 | DiscoverOption55: 1,33,3,6,15,28,51,58,59 | RequestOptions: 53,61,50,54,57,60,12,55 | RequestOption55: 1,33,3,6,15,28,51,58,59 | HostName: android-b6404a86d6c82d56 | VendorId: dhcpcd-5.5.6
16:02:49, 04 Mar.
16:02:44, 04 Mar.
wl0:A WiFi device <AC:EE:9E:23:B1:A9> has successfully connected to SSID (Device/WiFi/SSIDs/SSID[WL_PRIV5G])
16:01:32, 04 Mar.
wl0:Device <64:B5:C6:18:2F:25> was disconnected on SSID (Device/WiFi/SSIDs/SSID[WL_PRIV5G])
16:01:28, 04 Mar.
BR_LAN:The DHCP options that are offered by the device (id:13): DiscoverOptions: 53,57,55 | DiscoverOption55: 1,3,6,28 | RequestOptions: 53,50,54,57,55 | RequestOption55: 1,3,6,28 | HostName: | VendorId:
16:01:28, 04 Mar.
16:01:23, 04 Mar.
wl0:A WiFi device <64:B5:C6:18:2F:25> has successfully connected to SSID (Device/WiFi/SSIDs/SSID[WL_PRIV5G])
16:00:09, 04 Mar.
:HTTP UserAdmin login from 192.168.1.78 successfully
15:58:50, 04 Mar.
15:58:50, 04 Mar.
15:58:50, 04 Mar.
15:58:47, 04 Mar.
15:58:00, 04 Mar.
15:58:00, 04 Mar.
15:58:00, 04 Mar.
00:03:13, 01 Jan.
00:03:12, 01 Jan.
00:03:12, 01 Jan.
00:03:12, 01 Jan.
00:03:12, 01 Jan.
00:03:12, 01 Jan.
00:03:11, 01 Jan.
00:03:11, 01 Jan.
00:03:11, 01 Jan.
00:03:10, 01 Jan.
00:03:06, 01 Jan.
00:03:06, 01 Jan.
00:03:06, 01 Jan.
00:03:06, 01 Jan.
00:03:05, 01 Jan.
00:03:05, 01 Jan.
00:03:05, 01 Jan.
00:03:05, 01 Jan.
00:03:05, 01 Jan.
ppp:PPP: IPCP_NAK
00:03:05, 01 Jan.
00:03:05, 01 Jan.
00:03:05, 01 Jan.
00:03:05, 01 Jan.
00:03:04, 01 Jan.
00:03:03, 01 Jan.
00:03:03, 01 Jan.
00:03:02, 01 Jan.
00:02:48, 01 Jan.
00:02:40, 01 Jan.
00:02:36, 01 Jan.
00:02:30, 01 Jan.
00:02:29, 01 Jan.
00:02:29, 01 Jan.
00:02:29, 01 Jan.
00:02:15, 01 Jan.
00:02:15, 01 Jan.
00:02:15, 01 Jan.
00:02:09, 01 Jan.
00:02:09, 01 Jan.
00:02:09, 01 Jan.
00:01:11, 01 Jan.
00:01:11, 01 Jan.
00:01:09, 01 Jan.
00:00:51, 01 Jan.
00:00:49, 01 Jan.
00:00:49, 01 Jan.
00:00:49, 01 Jan.
00:00:41, 01 Jan.
00:00:41, 01 Jan.
00:00:40, 01 Jan.
00:00:40, 01 Jan.
00:00:39, 01 Jan.
00:00:39, 01 Jan.
00:00:39, 01 Jan.
00:00:39, 01 Jan.
00:00:39, 01 Jan.
00:00:39, 01 Jan.
00:00:39, 01 Jan.
00:00:39, 01 Jan.
00:00:37, 01 Jan.
00:00:36, 01 Jan.
00:00:36, 01 Jan.
00:00:36, 01 Jan.
00:00:36, 01 Jan.
00:00:36, 01 Jan.
00:00:36, 01 Jan.
00:00:36, 01 Jan.
00:00:36, 01 Jan.
00:00:36, 01 Jan.
00:00:36, 01 Jan.
00:00:24, 01 Jan.
15:48:19, 04 Mar.
15:48:19, 04 Mar.
15:48:19, 04 Mar.
15:48:19, 04 Mar.
15:48:19, 04 Mar.
15:47:32, 04 Mar.
Dudgers
@SammyM
3rd time i have posted this but it keeps disapearing*
16:04:05, 04 Mar.
16:04:05, 04 Mar.
16:04:05, 04 Mar.
16:04:05, 04 Mar.
16:04:05, 04 Mar.
16:02:51, 04 Mar.
16:02:51, 04 Mar.
16:02:51, 04 Mar.
16:02:49, 04 Mar.
16:02:49, 04 Mar.
16:02:44, 04 Mar.
16:01:32, 04 Mar.
16:01:28, 04 Mar.
16:01:28, 04 Mar.
16:01:23, 04 Mar.
16:00:09, 04 Mar.
15:58:50, 04 Mar.
15:58:50, 04 Mar.
15:58:50, 04 Mar.
15:58:47, 04 Mar.
15:58:00, 04 Mar.
15:58:00, 04 Mar.
15:58:00, 04 Mar.
00:03:13, 01 Jan.
00:03:12, 01 Jan.
00:03:12, 01 Jan.
00:03:12, 01 Jan.
00:03:12, 01 Jan.
00:03:12, 01 Jan.
00:03:11, 01 Jan.
00:03:11, 01 Jan.
00:03:11, 01 Jan.
00:03:10, 01 Jan.
00:03:06, 01 Jan.
00:03:06, 01 Jan.
00:03:06, 01 Jan.
00:03:06, 01 Jan.
00:03:05, 01 Jan.
00:03:05, 01 Jan.
00:03:05, 01 Jan.
00:03:05, 01 Jan.
00:03:05, 01 Jan.
ppp:PPP: IPCP_NAK
00:03:05, 01 Jan.
00:03:05, 01 Jan.
00:03:05, 01 Jan.
00:03:05, 01 Jan.
00:03:04, 01 Jan.
00:03:03, 01 Jan.
00:03:03, 01 Jan.
00:03:02, 01 Jan.
00:02:48, 01 Jan.
00:02:40, 01 Jan.
00:02:36, 01 Jan.
00:02:30, 01 Jan.
00:02:29, 01 Jan.
00:02:29, 01 Jan.
00:02:29, 01 Jan.
00:02:15, 01 Jan.
00:02:15, 01 Jan.
00:02:15, 01 Jan.
00:02:09, 01 Jan.
00:02:09, 01 Jan.
00:02:09, 01 Jan.
00:01:11, 01 Jan.
00:01:11, 01 Jan.
00:01:09, 01 Jan.
00:00:51, 01 Jan.
00:00:49, 01 Jan.
00:00:49, 01 Jan.
00:00:49, 01 Jan.
00:00:41, 01 Jan.
00:00:41, 01 Jan.
00:00:40, 01 Jan.
00:00:40, 01 Jan.
00:00:39, 01 Jan.
00:00:39, 01 Jan.
00:00:39, 01 Jan.
00:00:39, 01 Jan.
00:00:39, 01 Jan.
00:00:39, 01 Jan.
00:00:39, 01 Jan.
00:00:39, 01 Jan.
00:00:37, 01 Jan.
00:00:36, 01 Jan.
00:00:36, 01 Jan.
00:00:36, 01 Jan.
00:00:36, 01 Jan.
00:00:36, 01 Jan.
00:00:36, 01 Jan.
00:00:36, 01 Jan.
00:00:36, 01 Jan.
00:00:36, 01 Jan.
00:00:36, 01 Jan.
00:00:24, 01 Jan.
15:48:19, 04 Mar.
15:48:19, 04 Mar.
15:48:19, 04 Mar.
15:48:19, 04 Mar.
15:48:19, 04 Mar.
15:47:32, 04 Mar.
Dudgers
@SammyM
i have posted the log 3 times on here in reply to yourself and the posts disappears so sent via pm
Moderator's note by Dick (Strat): Posts released from Auto Spam Filter.
