INCREDIBLY unstable connection and speeds
DanMiller
I can’t live with this internet. Despite of supposed speeds of up to 60-70mbs, I can barely pull 5mbs. As I write this, I’m currently sitting at roughly 500kbps a second and I don’t understand. My receive and send speeds are all over the place and the Wi-Fi is borderline unusable. If anyone has any suggestions, please help!!!!!!!!
4 REPLIES 4
adam945
Fixes: 113
Re: INCREDIBLY unstable connection and speeds
Hey @DanMiller
Thanks a lot for reaching out and I'm really sorry to hear that you're having problems with your broadband service. Sounds like a fault on the line to be honest but it needs testing before I can provide any definitive answers.
I've not been able to find your Plusnet account through your Community Profile details, can you please send me a Private Message with your account username?
Moderator's note by Dick (Strat): Typo corrected.
 Adam
 Plusnet Help Team - Leeds
DanMiller
The username is canaria04. If you could manage to find the issue, it would be much help!
DanMiller
Fixes: 466
@DanMiller
If you don't send a Private Message you are relying on a Plusnet Staffer to come along and pick this up again.
If that has not yet happened then do this:
Click on @adam945 in the left hand pane of his message. On the right hand side you will see a Contact Me tab. Select this  and enter your username and refer to your post on the Fibre board.
Your message will then get put in a priority pool visible to all the Plusnet staffers who work on this forum. One of these will then pick it up for action.
