I am a Business ADSL Customer, what are my Fibre FTTP options with Plusnet?
- Full Fibre
- I am a Business ADSL Customer, what are my Fibre F...
30-11-2015 11:01 AM
Currently I have a business ADSL account with plusnet which I am pleased with. My village does not have a FTTC cabinet, and therefore is being Fibre enabled using FTTP. We will be connected in Q1 2016. Will I be able to order Fibre FTTP from PlusNet then, or will I have to switch provider?
Thanks,
Thanks,
Message 1 of 2
(1,266 Views)
1 REPLY 1
Re: I am a Business ADSL Customer, what are my Fibre FTTP options with Plusnet?
30-11-2015 11:28 AM
Quick answer yes you can order from Plusnet, details given below.
You need to check at https://www.btwholesale.com/includes/adsl/adsl.htm?s_cid=btw_furl_adslchecker_applications_diagnosti... and the first line of the results will say "WBC FTTP" if your property can get FTTP.
Ignore anything that say "FTTP on Demand" in the section called "Other Offerings" as Plusnet cannot supply that product and nobody is even sure if the product can be purchased as BT Wholesale put it on hold earlier this year.
If you can get FTTP then you can either go to BT Retail to sign up on-line or you can ask Plusnet via this URL http://trials.plus.net and select FTTP trial.
With Plusnet, the 2 contacted speeds available are 40Mbps down / 2Mbps upload or 80Mbps down /20Mbps upload. The price is the same as Plusnet's FTTC options.
BT Retail do 4 speeds, details given on their website,
Message 2 of 2
(361 Views)
- Full Fibre
