How to set up Hub Two for full fibre
Seneca
Hi, I'm moving to a house that doesn't have a telephone line, and we'll be using Full Fibre. The router Plusnet sent is a Hub Two but the instructions are about how to plug it into the telephone line. This must be a mistake, can anyone help me work out whether we can use this router but just need to set it up differently, or whether we need a different router altogether? Thanks.
3 REPLIES 3
Aspiring Hero
Fixes: 37
Re: How to set up Hub Two for full fibre
@Seneca
Does it have a Red WAN port (+three Yellow Lan ports).
If it does you plug an ethernet cable into the Wan port.
Seneca
Thank you - yes, it does have those ports. And what do I do with the other end of the ethernet cable?
Seasoned Champion
Fixes: 57
