How to join trial...
BeckyAP
Hello,
Complete newbie to this forum so please be gentle!
Moved into a new build property at the end of last month and it's come with FTTP.
We are still arguing with Openreach about things and waiting to get the call saying our line is ready....?
Can someone please explain the difference between FTTP and the "normal" internet I've used previously - why do only a few people offer FTTP services?
And also, once we are up and ready - how would I go about joining Plusnet on their FTTP trial?
Thanks guys!
Becky
8 REPLIES 8
Aspiring Hero
Fixes: 33
Re: How to join trial...
ADSL and VDSL (which is FTTC) use your phone line to provide a service. Speed is dependent on distance and quality of the line from the Exchange / Cabinet.
Fibre to the Premises (FTTP) uses a fibre optic cable run direct to your house. It is not limited by distance and can achieve far higher speeds than DSL services.
To join the PlusNet trial you need to be an existing PlusNet DSL customer.
Few ISP's offer a FTTP service because there are so few lines installed.
BeckyAP
Hi Brian,
Thanks for that information.
So does that mean, because I only have FTTP and am not a current Plusnet customer, I wouldn't be able to join the trial?
Oldjim
Fixes: 63
unfortunately yes
BeckyAP
Thank you guys for your help in this!
Aspiring Hero
Fixes: 33
If you new house has no standard phone line installed then you are stuck with FTTP. However, if you can get a phone line then you could sign up for a PlusNet DSL service then transfer to the FTTP trial. However, I suspect this would not be particularly cheap. Apart from paying for the phone line install you would almost certainly be on a 12 month contract. At the end of this you could cancel the phone service and just have FTTP.
With FTTP I know of only 3 providers though there may be others. BT Retail obviously plus
http://aa.net.uk/broadband-FP.html
https://www.zen.co.uk/yourhome/superfast-fibre-broadband-packages/fibre-to-the-premises/
Peterday
So, the great Plusnet support told me to go onto the Blog and signup for their FTTP trial. I've searched high and low and see nowhere where I can either signup or register interest.
Can someone please point me in the right direction?
Or do I just go back to BT?
Tags (1)
Strat
Fixes: 565
trials.plus.net.
HarryB
Fixes: 256
Hi @Peterday,
I'm sorry to hear someone has advised you that you sign up for the trial within the community/blogs.
The link @Strat has provided is where you can request to sign up for the trial, however I've checked your line and I'm afraid FTTP isn't currently available:
Featured Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Handback Threshold(Mbps)
WBC FTTC Availability Date
WBC SOGEA Availability Date
WBC FTTC 18x2 Provide Availability
WBC FTTC 18x2 Sim Availability
Left in Jumper
  High Low High Low
VDSL Range A (Clean) 17.7 11.4 1.2 0.8 10 Available -- -- Yes --
VDSL Range B (Impacted) 14.2 5 1.2 0.6 2.9 Available -- -- Yes --
Featured Products
Downstream Range(Mbps)
WBC FTTP Availability Date
FTTP on Demand 330 30 -- Available -- -- -- --
ADSL Products
Availability Date
Left in Jumper
WBC ADSL 2+ Up to 1 -- 1 to 3.5 Available -- -- -- Yes
ADSL Max Up to 1 -- 0.75 to 2.5 Available -- -- -- --
WBC Fixed Rate 0.5 -- -- Available -- -- -- Yes
Fixed Rate 0.5 -- -- Available -- -- -- --
Other Offerings
Availability Date
VDSL Multicast -- -- -- Available -- -- -- --
ADSL Multicast -- -- -- Available -- -- -- --
EDIT: To clarify, FTTPoD (Fibre To The Premises on Demand) is available, however this unfortunately isn't part of the trial. The availability checker would need to show WBC FTTP along the left hand side.
FTTPoD is considerably more expensive and in the past I've seen orders for this where the customer has had to pay 10's of thousands of pounds in excess construction charges, not to mention the minimum contract lengths and monthly subscription charge it also comes with.
 Harry Beesley
