How long does it take to get the router included with my upgraded package?
LordFox
My Full Fibre install is a week from today and I still haven't received the Hub 2 that is included. Does in usually arrive just at the last minute? I don't want to be left without internet, or even a way to check that everything is working while Openreach is still here.
6 REPLIES 6
Fixes: 334
Re: How long does it take to get the router included with my upgraded package?
@LordFox The Hubs are despatched (RM 24Hour Tracked) to arrive 2-3 days prior to activation. What router do you currently have?
LordFox
That's OK then, I'll stop worrying.
Officially, I have a Hub 1 I think, at least according to some notes I found. It's in a box in the loft somewhere.
My actual router is now a Mikrotik RB5009UPr+S+IN, which replaced an RB3011 a few days ago. I don't expect it will be a problem, but if there is an issue with the install it's simpler if I can say I'm using the official router for testing.
Fixes: 334
I suspect your current kit will work perfectly,  but if it doesn't yo can always use the Hub2 until you get it sorted.
Windings
Fixes: 14
@LordFox I've had a quick look on your plusnet account and have manually submitted the router order for you today just to be on the safe side. As @jab1 has already mentioned, our routers are sent via royal mail with tracking so keep an eye on your emails as we will send you the tracking ref once the router has been dispatched.
Ultimately your Hub 1 would work with the full fibre network anyways but i just wanted to make sure you received your fresh equipment prior to your install date.
All the best
Joe Elliott
LordFox
Thank you @Windings, much appreciated.
I'm getting all excited now... been waiting for fibre to arrive here for years. There's been a rush of activity from a competitor here recently, running around installing fibre and knocking on doors. I told them to go away; repeatedly.
Then, not long ago, I spotted Openreach down the road with a roll of fibre, so I knew it wouldn't be far off.
mwwagain
From my experience, posting the router is triggered by Openreach accepting the order and confirming the appointment.
My router not appearing (it was then manually sent as yours) was the main clue that Openreach would not be coming to do the installation but they had not bothered to tell anyone - me or Plusnet !
