How is ONT BOX attached inside the house?
- Full Fibre
- How is ONT BOX attached inside the house?
04-12-2024 2:32 PM - edited 04-12-2024 2:33 PM
Re: How is ONT BOX attached inside the house?
04-12-2024 2:41 PM
@walterwhite Sounds like the installer didn't do the job properly. The ONT (or at least the version I have) is secured by two longish screws and is rock-solid. My suggestion is you report this to PN as a faulty install.
04-12-2024 2:43 PM
Thanks I’ll contact them!
04-12-2024 6:08 PM
That's a hard approach to nipping up the two screws - see https://forums.overclockers.co.uk/threads/remove-openreach-ont-from-wall.18968872/post-36254634
04-12-2024 6:15 PM
Cheers @Townman . I didn't see him fitting the ONT (needed a coffee) but that all makes sense.
- Full Fibre
