Homebrew Router
neur0maniak
Homebrew Router
I'm curious as to how the ONT operates. I've read it has an ethernet port, so does this mean I can use a homebrew linux router without having to deal with authentication settings that exist in a VDSL router/modem? i.e. could a single computer connect directly to the ONT without using plusnets own router?
5 REPLIES 5
asm46598
Re: Homebrew Router
My understanding is you still have to authenticate.
Fixes: 118
Re: Homebrew Router
@neur0maniak
I'm not a techie but I understand you can use any modem / router that has a WAN port and is VDSL capable.
You can also connect a PC direct but it needs PPoE (I think) settings to work.
pjmarsh
Fixes: 24
Re: Homebrew Router
@bmc, for a Full Fibre product it wouldn't need VDSL at all, but yes, anything with a PPPoE client could connect.
@neur0maniak, that would also have been possible on any of the FTTC products as well with a VDSL modem.
Fixes: 480
Re: Homebrew Router
@neur0maniak
 Yes you can use a computer to connect directly to the ONT. You still need to set up authentication on the PC. It should be PPoE with your Plusnet username in the form <username>@plusdsl.net and your account password. This article tells you how to connect a modem to a windows PC. The same procedure is required. I have no doubt that there are similar facilities with Linux.  https://www.draytek.co.uk/support/guides/kb-vigor-130-windows
neur0maniak
Re: Homebrew Router
Thank you for your responses everyone, it's helped me prepare.
