Help - where do I start?
harryw2806
Just joined this community as we don't know where to start with initial problems.
Upgrading to Full Fibre FTTP, from Plusnet with installation day today. Engineer overdue, no messages at all regarding cancellation/rescheduling etc. Hardware has arrived, a few days ago. Have tried the customer service number, but computer says no to mobile phone number - it's invalid! Really?! Don't use X, so where do we go from here?
Reading some of the issues on here doesn't particularly fill me with faith.
Any help/suggestions gratefully received.
Harry
23 REPLIES 23
Fixes: 392
Re: Help - where do I start?
@harryw2806 Are you moving from another ISP, or merely upgrading a PN contract?
If you ring Plusnet, the computer won't say no, you will just be placed in queue. Which number did you call?
harryw2806
Hi John,
thanks for the quick response. Should have been clearer, but it's an upgrade from older Copper Wire Plusnet connection to full fibre. Phone number used was 03301239123, asks for your phone number, rejects it as not recognised and then dumps the call. I'm guessing it's not the right number?
many thanks,
Harry
outcast
Aspiring Champion
Fixes: 19
@harryw2806
Try answering with your copper landline's phone number ?  (rather than the mobile number you are calling from)
Fixes: 392
Don't understand that, @harryw2806  - I have just called that number from my mobile, and got connected via option 3 on the IVR system. Cancelled the call once I got a ringing tone, as I am no longer a PN customer.
FYI - your existing connection will reman active until the installation engineer turns up.
Fixes: 586
@harryw2806 are you sure today is the confirmed date for FTTP install ?
Might be worth logging in to your Plusnet account and checking to see if there are any closed questions (tickets) that migt indicate whats happening. Login to the member center and then go to https://www.plus.net/wizard/?p=search , use the drop down to select closed questions in the last 7 or 30 days
Fixes: 118
@harryw2806
The engineer could just be running late.
Try logging into your PN account and see if there are any Open Questions under My Order. If PN have been informed of a problem there should be a message.
outcast
Aspiring Champion
Fixes: 19
@harryw2806
... while in the Member Centre, go to https://www.plus.net/member-centre/account
and check that the mobile phone you are using is registered in your contact details ?
Fixes: 392
@outcast See my post above - I got a connection to the required team without any problem, and PN are not even my ISP.
outcast
Aspiring Champion
Fixes: 19
@jab1  did the 'computer' ask you for a phone number though ?
I think @harryw2806  got further through the menu system than you,  because I makes no sense 'asking' what is your phone number when the 'computer' would have been able to read the incoming CALLER ID.
I'm reading this as the 'computer' saw an incoming mobile call, from a number not registered in the Plusnet system, and therefore is asking for the landline number associated with the broadband that is being enquired about ?. (although who knows how that would work on FTTP or SoGEA).
Fixes: 392
My mobile number is not on the PN system, and I got all the way through the system.
harryw2806
Hi Brian,
there seems to be an open question from a few days ago. It confirms the installation date etc on one message, but the next says that the open question has been held over until 04 February (tomorrow) at 09:00. Is this some jibberish way of telling us that the installation has now moved to tomorrow?
Thanks,
Harry
harryw2806
thanks,
already checked that and contact number is the mobile number it rejected.
Harry
Fixes: 392
I don't understand that, @harryw2806 - as I said, I got straight through to the correct section, and my number isn't even on PN's system.
@harryw2806
A suggestion might be to call hiding your CLI (Call Line Identifier), think you add 141 to the start of the number you are calling.
Edit: Works with Vodafone
