Help! BT Engineer unable to successfully complete FTTP on 11th Feb - what now?
- Full Fibre
- Help! BT Engineer unable to successfully complete ...
16-02-2011 10:36 AM
I registered for the PlusNet FTTP trial (as I am close to the MK Bradwell Abbey Exchange) and had my appointment with a BT engineer scheduled for last Friday 11th Feb. The engineer (just the one) turned up and told me this was his "first" PlusNet FTTP job, and he had not done one before. He also said it should be a 2 man job. However, he started off, and the initial (potentially problematic) feeding of the fibre cable went OK, and he cabled up the house and fitted my ONT. After several visits to the nearby cabinet etc., at around 4.30pm (having arrived at 8.00am) he announced that he could not get it to work. "There should be a green light on your ONT" but there was none. He said I would need to find out from PlusNet what happens next - so what DOES happen now? He said the job would be marked down as a "failure" as he was not able to complete it successfully, but I do not know who then picks it up and resolves. I am concerned that he was not sufficiently knowledgable (and had not done one of these jobs before - and was "on his own") that he did not have the expertise to complete the job correctly. I was so looking forward to getting my fibre connection up and running, but am now left hangning. I have all the equipment fitted, but need someone who knows what they are doing to ge the optical connection up and running.
Any advice/help please???
Andy (PlusNet username = subtract)
Re: Help! BT Engineer unable to successfully complete FTTP on 11th Feb - what now?
16-02-2011 10:57 AM
I'd guess you need to put a fault ticket in and get another Open reach crew on it.
16-02-2011 11:15 AM
Andy
16-02-2011 11:47 AM
16-02-2011 12:17 PM
I'm expecting an update later today or tomorrow and I'll let you know what they say.
Plusnet Technology
16-02-2011 12:30 PM
This is a FTTP install right? So I am presuming there is a trunk fibre going from the exchange to the roadside box, and then from the box to the customer site?
Now, it would appear to me from what has been said the engineer successfully fed a fibre from the cabinet to the consumers site, but the error indicates that the fibre from the exchange to the cabinet is broken?
One of things I'm really curious about, is when did BT dig up all the roads and lay the fibre from the exchanges to this cabinets, or am I missing something?
Every time I read about the FTTC/FTTP trails I'm left thinking that either fibre has been being installed between exchanges and cabinets for many years now and we could all switch to FTTP very soon, or that something mystical is happening that enables cabinets to provide FTTC services, I'm also left wonder why if a cabinet (all cabinets?) can do FTTC that they cannot do FTTP.
Please can someone explain the physical process and layout of this to me?
16-02-2011 12:39 PM
I'd guess that getting fibre to premises is a bigger job altogether, but the last few metres from the local street cabinet to the premises on copper is an acceptable alternative for many.
16-02-2011 1:07 PM
16-02-2011 1:16 PM
Quote from: fourfourdevon
When you walk down the street do you not see BT/GPO man covers? These are for access to underground ducting which are being used to run the fibre. So the first FFTCs are the ones that are connected through underground ducting, ones that are not probably be upgraded later as they will require the road/paths to be dugged up.
16-02-2011 1:20 PM
Andy
16-02-2011 1:20 PM
But what I can't buy, is that actually, that's simply not true, and all that's required for a large part is for a cable to be pulled.
Well if that's all it is (cable pulling) then the costs of fibre to all drop dramatically and give a lie to first argument.
Also, if a cabinet is FTTC enabled, what possible physical property prevents the cabinet from offering FTTP services?
16-02-2011 1:33 PM
The length of overhead fibre cables and the affects of the weather on it.
16-02-2011 1:39 PM
16-02-2011 2:18 PM
Quote from: brassedoff armoured multicore cable with breakout to your property.......
DSLAMs
Armoured cable
FTTC use MSAN not DSLAM.
16-02-2011 2:25 PM
That doesn't gel with the OP, which says this is FTTP and that the cable was pulled.
Quote from: brassedoff Thus, to get fibre from your cabinet to your home either involves digging up the street or running fibre up and down telegraph poles depending on how you connect back to the cabinet.
- Full Fibre
