Has the trial ended?
- Full Fibre
- Has the trial ended?
30-11-2017 11:32 AM
One has already phoned up this morning. She is an existing PlusNet customer but has been told the trial is no more. Is this really the case or do some people just not know how to deal with that enquiry?
Re: Has the trial ended?
30-11-2017 11:46 AM
Because it's a Trial it's not been integrated into PlusNet back office systems. Hence if you speak to a customer advisor they'll likely know little if anything about it.
Very few staff have been trained up on it and the only real support is through this forum.
If your neighbour wants FTTP she'll need to login to her PlusNet Members page and submit a Support question at
https://portal.plus.net/wizard/?wizard_id=20
30-11-2017 11:46 AM
That's certainly not the case as far as I'm aware.
If she wants to sign up she'll need to do it by going here as it can't be done over the phone.
30-11-2017 11:58 AM
Would you mind telling us how the cost of FTTP with Plusnet compares with what BT would charge? Thanks.
30-11-2017 12:01 PM
The PlusNet FTTP packages are based of their FTTC products - same price and speeds. It should be noted they are for PlusNet customers only.
The bonus is you can, if so desired, cancel your phone line after you're up and running. There is a surcharge of £2.50 a month for no line but it works out at £17.49 a month for an up to 38 service.
30-11-2017 8:57 PM - edited 30-11-2017 8:57 PM
This is partly correct. The costs are based on the FTTC products without any discounts.
So for Unlimited Fibre Extra it's £19.99, or Unlimited Fibre it's £14.99.
Add line rental of £18.99 on to that. However as Brian has advised, once the FTTP is up and running you can choose to drop the line rental and pay £2.50 more to the fibre package, though you may need to pay off the phone side of the contract.
