Halved speed…
Creed01
Halved speed…
I just wanted to have agreed internet plan which all parties would be fine adhering to, turns out this isn’t the case. After agreeing to a full fiber 145 for a reasonable fee, a few weeks went by and it was quality.
however. It turns out my Estimated download speed: 145 - 160Mbps is more like 70mbps, now people. Im all for a little sway each way. This is more like flipping the boat over in a riptide…can I at least have an answer as to why my speed is nearly halved?
Thanks I guess.
5 REPLIES 5
Fixes: 388
Re: Halved speed…
@Creed01 This is probably a BT/OR network problem, especially if it has suddenly happened. Unfortunately, I can't offer an explanation or solution, but I have asked for the topic to be moved to the Full fibre board, where someone may be able to help.
Mustrum
Fixes: 81
Re: Halved speed…
What makes you think it has?
Fixes: 1,495
Re: Halved speed…
Moderators Note
This topic has been moved from Broadband to Full Fibre
Fixes: 118
Re: Halved speed…
@Creed01
With Full Fibre you should get close to the advertised speed over a wired connection.
If you're not getting said speed then there's a network / account problem somewhere.
willcutforth
Fixes: 113
Re: Halved speed…
Hey there @Creed01 and a warm welcome to the forum.
There is an issue on VLAN according to the tests so I have raised this over to OR and they should fix it within 72 hours but I will keep an eye on it for you Smiley
 Will Cutforth
