Guatanteed BB Speed
TW
Guatanteed BB Speed
My contract was renewed in November 2021.
Plus net guaranteed a speed of 39Mbs and I am getting about half of that (according to Speedfix),
Prior to contract change things were good and I had no complaints.
Am I doing something wrong or is it a problem?
13 REPLIES 13
Fixes: 368
Re: Guatanteed BB Speed
@TW Don't know if you are 'doing anything wrong', but if you supply the requested information from the text below, we may be able to help:-
For Community members to be able to help, information from these two sites:-
BT Broadband(obscuring your phone number) and BTW Performance Tester - Over a wired (ethernet) connection please report the 'Additional Diagnostics', and sight of the Help Desk tab from your Hub would be a start.
It may also be a good idea to report the results of a Quiet Line Test - dial 17070 option 2 from a (preferably corded) phone. After the confirmation of you phone number, there should be total silence apart from the regular 'Quiet Line Test' announcement. Any other noise - report a PHONE fault first.
If phone test is OK then take the front off your telephone master socket, you may need to remove two screws. In behind you will find the test socket. Plug a filter in here and connect that to your hub. If it’s still dropping out then report a fault at https://faults.plus.net.
Fixes: 109
@TW
Are you testing using a fixed or WiFi connection?
It's the fixed conenction speed that matters in the first instance.
Fixes: 368
Good point, @bmc - although I  think my post mentioned the use of a wired connection for testing?
TW
@jab1 , @bmc
Thanks for the guidance.
It is a wired connection and I'll do the tests tomorrow and post my findings.
I'm grateful for the help (apology for the heading spelling mistake).
Fixes: 1,655
Thanks for your post @TW
I'm really sorry to see you're having speed issues.
I've tested your line today and the tests aren't showing the cause for this, but I can see your router's getting 39mbps still. This however is below where we'd expect your line to achieve of between 49mbps to 68.8mbps.
Let us know how the above checks go, if you're still having issues I'd be happy to arrange an engineer visit for a closer look.
TW
@jab1 , @bmc, @Gandalf
The results of the tests suggested are :-
I did not understand the output of this complex page but I saved the html page for reference with guidance from the forum if advised.
PING 8 ms
DOWNLOAD 34.52 Mbps
UPLOAD 8.36 Mbps
Quiet line was silent
You will see that I find this difficult but from what @Gandalf says it would seem that my difficulty lies on my side of the router (Netgear WNDR 3700V4) so should I shutdown and reboot in the hope that that will fix it?
TW
Much to my surprise the saved html page did not preserve the data,
I'll try again and see if a screenshot is more helpful
TW
I tried again and this is the (text saved) somewhat inadequate result.
All the headings are messed up, my apologies to all:-
Broadband Availability Checker
Featured Products Downstream Line Rate(Mbps) Upstream Line Rate (Mbps) Downstream Handback
Threshold(Mbps) WBC FTTC Availability Date WBC SOGEA Availability Date
High Low High Low
VDSL Range A (Clean) help 68.8 49 17.6 11.6 44 Available Available
VDSL Range B (Impacted) help 67.1 45.6 17.2 10.6 39.4 Available Available
Featured Products Downstream Line Rate(Mbps) Upstream Line Rate (Mbps) Downstream Range (Mbps) Availability Date FTTP Install Process
FTTP on Demand 330 50 -- Available --
ADSL Products Downstream Line Rate (Mbps) Upstream Line Rate (Mbps) Downstream Range(Mbps) Availability Date
WBC ADSL 2+ Up to 6 -- 4 to 8 Available
WBC ADSL2+ Annex M Up to 6 Up to 1 4 to 8 Available
WBC Fixed Rate 2 -- -- Available
Other Offerings Availability Date
VDSL Multicast Available
ADSL Multicast Available
Exchange Product Restrictions Status
FTTP Priority Exchange N
WLR Withdrawal N
SOADSL Restriction Y
The exchange is not in a current fibre priority programme
WLR is currently available at the exchange
SOADSL is restricted at the exchange
FTTP is not available.
For all ADSL and WBC Fibre to the Cabinet (VDSL or G.fast) services, the stable line rate will be determined during the first 10 days of service usage.
Actual speeds experienced by end users and quoted by CPs will be lower due to a number of factors within and external to BT's network, Communication Providers' networks and within customer premises.
Fixes: 368
@TW Thanks for those above posts. For reference, they are much easier to read and understand (from my perspective) if you do a screen grab of the actual page and upload the actual pictures.
Unfortunately, I don't know your modem/router, but is there somewhere on there which gives your current speed/uptime &c?
The 'details' from the BT Broadband page are incomplete - hence why full screen grabs are important.
TW
I've tried again...thank you for your patience....
Fixes: 368
@TW Thanks for that last post - much easier to understand, although the phone number rather than address checker would have given us an idea of your current speed - although IIRC, @Gandalf has already indicated that the speed to your modem/router is already below expectations.
Quite honestly, my thoughts at the moment are that you need investigation by BTOR.
@Gandalf - time to wave your magic wand?😉
Mustrum
Fixes: 81
Before OR, there are the other points in @jab1  post:
TheMightyAJ
Fixes: 126
Hey @TW,
Thanks for sending this info over. I think the best course of action would be to arrange for an engineer to come out to the property and have a further look at things. I've raised a support ticket on your account concerning this, which can be accessed here. Please let us know once you've had a chance to read and respond to it and we'll be happy to pick this back up for review as soon as possible Smiley
 Alex H
