Google WiFI with FTTP and Hub One
- Full Fibre
- Google WiFI with FTTP and Hub One
on
01-12-2017
10:14 AM
- last edited on
05-12-2017
5:37 PM
by
Mav
Has anyone set this up with their FTTP installation?
At first I thought my line speed was not up to the promised 76/19 but having done wired speed tests I can see it is working just fine and any issues about speed over wifi are therefore down to the Hub One performance.
I am considering adding something like Google WiFi to provide more reliable speed and coverage. In all honesty, the Hub One seems ok for coverage but the speeds seem highly variable. I'd also like to be able to set priority devices so that no one device can hog the network to everyone else's detriment. Google WiFi seems to fit the bill but I have a couple of concerns.
1.) Can I use it with the Hub One? From what I read the Hub One will not act as a modem only and so I'd have to replace it with another modem. That said with FTTP is the ONT from Openreach not acting as the modem? Can I plug straight the Google WiFi or other router straight into that?
2.) Ethernet Ports - One good thing about the Hub One is I can connect my Hive Hub, Sonos Hub and wireless oil meter via Ethernet. Google WiFi seems to be poorly equipped with Ethernet ports so I'm wondering how I will connect everything up. I believe I could buy a switch for a tenner that might solve that.
Am I wasting my time going down the Google WiFi route? Do I just need a better router? Most of them are ugly as hell so I'd want to hide it and I could really do without a crazy configuration panel. Google at least seems to keep it simple as far as that is concerned.
Would be good to hear if anyone else has done this. I've seen other posts in the community but not specifically relating to FTTP and whether the Openreach equipment changes things.
Gavin
Moderator's note by Mike (Mav): Post released from Spam Filter.
Re: Google WiFI with FTTP and Hub One
10-12-2017 9:25 PM
I’m very happy with it and particularly like being able to prioritise a device to protect its bandwidth and remote access whereby I can run speed tests and see who is on the network and at what speeds while I’m away from home. Recommended.
10-12-2017 11:00 PM - edited 10-12-2017 11:07 PM
gavcuk wrote:1.) Can I use it with the Hub One? From what I read the Hub One will not act as a modem only and so I'd have to replace it with another modem. That said with FTTP is the ONT from Openreach not acting as the modem? Can I plug straight the Google WiFi or other router straight into that?
You connect Google WiFi to the ONT, the Hub one is redundant
Yep, just buy an ethernet switch to provide the extra ports you need
22-01-2018 5:24 PM
28-01-2018 7:08 PM
28-01-2018 7:24 PM
Nice, so the ONT BT Modem plugs directly into the Google wifi and you were able to access the internet after setting up connection details? (I thought spending £299 on a TP-Link VDSL WiFi router was an expensive solution but it proved me wrong).
28-01-2018 7:27 PM
My next goal is to bin the landline and use VoIP!
28-01-2018 7:46 PM
VoIP should hopefully eliminate cold callers too......for the time being.
Thanks for answering, it's really cleared a ton of awkward questions to google technical support! I'll seriously consider it. Do you happen to stream 4K content to your TV via netflix or similar as I saw the transfer speeds of the google wifi weren't too quick.
28-01-2018 7:54 PM
The wired line speed tends to be 68-74.
28-01-2018 8:11 PM
Great, seems good enough. Netflix 4K requires transfer speeds of 25mbps or more so that should be plenty! Thanks again. Very helpful.
- Full Fibre
