Full fibre not reaching min speeds
Fixes: 334
Re: Full fibre not reaching min speeds
Sorry, @MisterW , I know it's early on a Saturday morning, but I can't quite understand your comment above.😁
outcast
Aspiring Champion
Fixes: 19
@MisterW wrote:
the hub 2 is WiFi, Iup until recently I had a WiFi router and would get around 400Mb under ideal conditions on my WiFi 6 laptop . I ve just changed to a WiFi router and the lappie now gets around 800Mb.
My translation ? -
the hub 2 is WiFi 5, up until recently I had a WiFi 5 router and would get around 400Mb under ideal conditions on my WiFi 6 laptop . I ve just changed to a WiFi 6 router and the lappie now gets around 800Mb.
Fixes: 334
Sounds reasonable, @outcast . I've not had my caffeine fix yet, so maybe brain isn't lubricated. 😉
outcast
Aspiring Champion
Fixes: 19
No @jab1 , it's not you, I thought the same, I think @MisterW wasn't awake when he posted at 6:07 !
Just making my coffee now 😉
Fixes: 334
A thought. Providing the OP has nothing (like doorbells/smart lights), that explicitly need 24Ghz, maybe they could disable that band on the Hub, the they would force everything to use the 5Ghz.
outcast
Aspiring Champion
Fixes: 19
Yes, that is what I'd do - if I was only relying on the supplied Hub Two (and not bothering to use proper WiFi access points)
You have to wonder why anyone needs more than 250Mbps already being achieved over WiFi.
Fixes: 334
Big family, loads of devices in use, running a business at home?
outcast
Aspiring Champion
Fixes: 19
.. and not have an ethernet cable in the house ?
Fixes: 334
Not unknown - I've seen a few posts from people with the same issue. Having said that, I have quite a few, collected over the years, but never use them.
Protech
Fixes: 7
A significant and increasing number of households are WiFi only these days. Especially amongst the younger demographic.
Some ISP's have a built in on net speed test built into their supplied routers which removes the need for external devices to test. Not sure if the Plusnet routers still have this ?
You can check out but you can never leave ( easily)
bill888
Champion
Fixes: 40
Who was your previous ISP?  What speed of service (500mb?) ?  What model hub did previous ISP provide to you?
As pointed out by others, ISPs only guarantee speeds with an ethernet connection.
Some ISPs also offer minimum 'wifi' speed guarantee to any room, some times at extra cost.
eg. Sky used to quote minimum of 3 Mbps to any room, but I see they have upped it to 25 Mbps for full fibre products with their new wifi-6 hub.
The Hub 2 is an old Wifi-5 router from 2019.  Best you're likely to get is 400 Mbps over 2x2 wifi in same room as hub? Most smart phones only have a single antenna (1x1) so may only see half the speed, eg. 200 Mbps
On ethernet, I see 518 Mbps down, 72 Mbps up.
On wifi using my laptop with 2x2 wifi to my old Asus wifi-5 router about 3m away through one stud wall, I currently see 418 Mbps when I made this post, but have seen highs of 470 Mbps.
Maximum possible wifi speed is 'typically' around half the link speed reported in Windows btw.
Fixes: 524
Oops! Yes @outcast interpreted my gobbledegook correctly
Fixes: 457
@oliveoyl983 wrote:
We seem to struggle to reach min speeds. I spent an hour last month on the phone with them going through all the usual, After this hour it reached min levels but it's dropped off again.
Does does it get any better or do they keep turning it down 😒.
To try to get this thread back on topic.
There is a general misunderstanding regarding guaranteed speed. This is the speed that is supplied to your router and can be fully accessed by connecting a computer directly to the router using the provided Ethernet cable.
Plusnet are unable to 'turn your speed down'. There is no plot to rob you of your contracted speed.
Evidence suggests that your router is receiving the full contracted speed and your problem is the wireless link to your devices. This is beyond the control and outside of the responsibility of Plusnet.
As has been suggested, your problem is either the distance between the router and your devices or interference caused by neighbours using the same WiFi channel. I suggest that you follow advice already offered and come back with the results of your tests and/or ask for more specific advice. To help members help you, describe your set up, such as the distances involved and whether there are walls and/or floors between the router and your devices.
HPsauce
Seasoned Pro
Fixes: 5
You can easily check the speed your router is connected at, even from a mobile device.
Open your favourite browser (e.g. Safari on an iPhone) and type 192.168.1.254 into the search and enter, you should see (eventually) the Plusnet Hub Manager  screen.
Just tap on  Status near the top and you'll see the connection details. Status, type, downstream and upstream speeds, uptime etc.
@oliveoyl983 what are the downstream and upstream speeds reported and the connection type?
Fixes: 122
@HPsauce
Here is an example of the Hub Two status screen for full fibre
Only the WAN speed is reported
