Full fibre not reaching min speeds
oliveoyl983
Re: Full fibre not reaching min speeds
Our screen looks like the screenshot you show but there is nothing for uploading or downloading speed don't worry all thanks for your help but this is all a bit beyond me however thank you all for trying 🙏
Fixes: 306
@oliveoyl983 Sorry - we did go off at a bit of a tangent but can you answer these questions:-
What computers/tablets/phones do you have in the house?
Where are you getting your speeds from?
HPsauce
Seasoned Pro
Fixes: 4
@oliveoyl983 We just need to know the WAN link speed (and connection type as requested). Upload/download refer to a slightly different technology where there are two different speeds, yours is probably the same both ways.
Fixes: 306
Not on PN, @HPsauce .
grumble
@HPsauce wrote:
You can easily check the speed your router is connected at, even from a mobile device.
Open your favourite browser (e.g. Safari on an iPhone) and type 192.168.1.254 into the search and enter, you should see (eventually) the Plusnet Hub Manager  screen.
I will note that the 'answers' supplied by the browser are somewhat lacking.
Fixes: 306
Are you using a Plusnet  hub, @grumble ?
grumble
Short answer.
Yes.
Fixes: 306
Slightly longer reply: Strange.
Marsh
Fixes: 18
Hey @grumble,
That is a strange one, I have never seen when it takes too long to connect to the hub manager.
I would like to take a look into this for you however I have failed to find your account please can you reply to my DM with your plusnet username.
Josh
grumble
Don't worry. It is working. It is just that the hub address isn't the default 192.168.1.254
Fixes: 306
Then why try it?Huh
grumble
I forgot.
