Full fibre LOS light on
crash19999
Hello, I have just got home and have the red LOS light on the Openreach box, I have tried resetting the box numerous times and still the light comes back on. Is there someone who knows how to fix this?
10 REPLIES 10
RealAleMadrid
Fixes: 66
Re: Full fibre LOS light on
@crash19999  There's no way you can fix it, you need to report a fault to Plusnet. LOS means loss of signal, there is a break in the fibre somewhere, or a fault at the exchange end.
crash19999
Thank you for the reply will contact them now.
willcutforth
Fixes: 113
Hey there @crash19999
Sorry about the issues with you BB I can see you have contacted and got an appointment booked. Do you need me to do anything else?
 Will Cutforth
irenec86
I am having the same issue. How can I report it? Please help.
Fixes: 531
https://www.plus.net/help/report-a-problem/broadband/
irenec86
@MisterW yeah thanks. I got there but it is not helping. I have the Openreach box LOS red light on, which means it is an external issue and just needs reporting to Plusnet. I sent a text as instructed and even called, but I am not sure whether my issue is being investigated because I received no feedback from anyone.
Fixes: 531
Login to your account and see if there any any 'tickets' (questions) . You may need to use the link https://www.plus.net/wizard/?p=search when logged in. Look for open questions and closed questions
irenec86
No open questions :(((
Fixes: 531
In that case, I suggest calling in again to check that the fault has been recorded
MatthewWheeler
Fixes: 503
Morning @irenec86
I'm sorry to hear that your connection is down at the moment.
I can see you've spoken with our support team about this and an engineer is due out today.
Let us know how you get on
As of the 1st of January 2026, I no longer work in Plusne,t so I'll be unable to assist you with any queries.
