Full Fibre Speeds
dartilov
Full Fibre Speeds
Good afternoon
Last Friday we had Full fibre 500 installed and I just wanted to know how long before we can expect to see that kind of speed on the line on a regular basis.
it's certainly an improvement on normal broadband both upload and download but tests are showing a wide variation in speed and I thought it should be fairly constant?
Many thanks
2 REPLIES 2
SpendLessTime
Fixes: 86
Re: Full Fibre Speeds
If you are testing via an Ethernet cable then the speeds should be consistent with the product ordered from day one. If you are testing via Wi-Fi, which is a black art, then speed tests aren't reliable using that technology.
edit for spelling
Madudzik
I'm on 500 full fibre for nearly 3 months and speed is 500/75 with low ping, never dropping...
