Full Fiber Product Change
paldridge90433
I've recently opted to upgrade from 300mb to 500mb - Can anyone give an insight to what happens on the day of the porduct change? Is it just simple case of rebooting the router to get the new speed?
1 REPLY 1
Re: Full Fiber Product Change
@paldridge90433
I'm not sure that you will even need to reboot the router?
You might have to reboot the ONT though?
The speed increase will only affect the link between Plusnet and the ONT - the link between the router and the ONT should already by synced at 1Gps - if it isn't, you won't be getting anywhere near 300Mbps now! (The maximum you would be getting is 100!).
