Full Fiber 900 Download speed 100-130
FIXED- Subscribe to RSS Feed
- Full Fibre
- Full Fiber 900 Download speed 100-130
02-10-2023 11:02 AM
Fixed! Go to the fix.
Re: Full Fiber 900 Download speed 100-130
02-10-2023 11:21 AM
I would try with a different cable, especially as you are seeing higher speeds with WiFi.
02-10-2023 11:26 AM
Hi @nshezz
As you are seeing 100 mbps on the upstream it indicates that you have been provisioned on the correct package.
Only the 900 mbps downstream package supports 100 mbps upstream.
WiFi 5 as provided by the PN Hub 2 and most WiFi client devices would probably struggle to be much faster than 300 mbps.
To get the full 900 mbps on one device, Ethernet is the way to go.
Looking at Ethernet result, having over 100 mbps on the downstream should rule out a faulty Ethernet cable.
Are you using the Plusnet Hub2 router?
What device on Ethernet are testing the speeds with?
Some Windows anti virus packages are known to reduce download speeds.
Regards
Richard
02-10-2023 11:27 AM
Thanks for the reply, i'm using cat6 cable directley to the router to pc tried 3 other cat6 cables and the result is the same. i've tried looking to see if windows 11 is the issue with ethernet settings and my linkspeed is 1gps.
02-10-2023 11:30 AM
You could try booting a linux live distribution:
https://itsfoss.com/linux-mint-live-usb/
and then perform a speed test.
02-10-2023 11:33 AM
I'm using Plusnet Hub2 router, here is my device spec
Processor 12th Gen Intel(R) Core(TM) i9-12900KF 3.20 GHz
Installed RAM 64.0 GB (63.8 GB usable)
System type 64-bit operating system, x64-based processor
Pen and touch No pen or touch input is available for this display
2.5gbs realtek pci ethernet card connected directley from PC to router.
I'll retry without anti virus and update.
02-10-2023 11:34 AM
Will do i'll upload the result.
02-10-2023 11:45 AM
An alternative to the speedtest GUI is speedtest cli which provides more detail on the test performed
See https://www.speedtest.net/apps/cli for details and downloads
02-10-2023 12:37 PM
Hi thanks for the reply, here is a screenshot of the cli result, i used linux mint and ended up at 151 mbps and disabled my anit virus on windows 11 and still no joy.
02-10-2023 12:41 PM
02-10-2023 1:00 PM
It might be worth checking the driver for the ethernet adapter is the latest Realtek published version and not published by Mircosoft.
03-10-2023 11:36 AM - edited 03-10-2023 11:48 AM
Have you ever seen higher speeds, for instance when transferring files on your local network? Your PC should easily manage much higher speeds, but since it is slow in both Windows 11 and Linux Mint it suggests the issue is either the PC hardware, the cable, or the router (i.e. not software or drivers).
EDIT: I just thought to test the speedtest server in case that was the limiting factor - I get
Server: M247 Ltd - Manchester (id: 48181)
ISP: Gigaclear Limited
Idle Latency: 12.23 ms (jitter: 0.04ms, low: 12.18ms, high: 12.24ms)
Download: 605.35 Mbps (data used: 477.7 MB)
16.07 ms (jitter: 0.33ms, low: 10.90ms, high: 28.61ms)
Upload: 615.74 Mbps (data used: 482.6 MB)
11.01 ms (jitter: 0.28ms, low: 10.58ms, high: 11.47ms)
Packet Loss: 0.0%
Result URL: https://www.speedtest.net/result/c/95837151-9718-4ac6-832f-9aad7b70babd
For London servers I get much lower latency, but otherwise similar results.
05-10-2023 2:11 PM
Okay bit of an update, i have tried everything reset ONT and router used every port checked every connection reset my network adapters with realtek drivers and flushed my DNS and winsock logs.
I even bought my own cat 6 cable and Ethernet crimping tool and tester just to make sure that everything on my end was working correctly.
It maybe could be the router or a fiber issue outside. Nothing i do improves my speed which is a shame because i was looking forward to being able to download large games without the wait. defiantly not the 500mbps minimum i was guaranteed. I've truly run out of things to try on my end so if anyone has any other ideas please let me know.
05-10-2023 2:18 PM
How about logging into the router and seeing if you have a 1Gbps reported on the WAN link?
Or by-passing the router and set up a PPOE session from a PC/Laptop?
05-10-2023 2:19 PM
You could eliminate the router by setting up a PPPoE connection on the PC LAN card and connect it directly to the ONT.
Lots of help online for instructions.
HTH
- Full Fibre
