Fritz!Box 7590 slower than a cheap modem or is my line faulty again ?
- Full Fibre
- Fritz!Box 7590 slower than a cheap modem or is my ...
- « Previous
- Next »
Re: PN Read Please - Re: Fritz!Box 7590 slower than a cheap modem or is my line faulty again ?
10-06-2018 12:04 PM - edited 10-06-2018 12:06 PM
OK, I found my old BT Open Reach modem, I've connected and configured it as described in the PPPoE direct connection.
I can get to most sites, but the BT Speed Test site was not accessible or was off line so I used Think Broadband, Which Speed Test and Speedtest.net instead, all of which gave a result of around 28Mbps, but until my DLSAM max increases back up to 40Mbps my download speed will remain slow !
I will leave it connected today to see if it makes any difference, but looking at my Think Broadband daily graphs the external interference referred to in the above post by the BT engineer is not constant I can see it was present for an hour (5am to 6am) and for 12 hours (2pm to 2am) on different days >
on
10-06-2018
3:36 PM
- last edited on
10-06-2018
7:08 PM
by
Mav
Hello @daveg6hni,
Thanks for getting back to us. We will need to arrange an engineer to investigate the issue further. I updated your fault ticket here, and please let us know once you have updated it with your availability, so we can progress you fault further.
Moderator's note by Mike (Mav): Changed font size to make post more readable.
10-06-2018 5:59 PM
I have updated the ticket, basically Friday 15th AM or PM or Monday 18th AM or PM
But before you book can you please check my line with the old BT OR modem connected as I cannot see my line stats anymore.
11-06-2018 8:33 AM
Line tests are showing your router in sync at 31mbps still.
Unfortunately it looks like the speed estimates of your line have since dropped to 30mbps. This can be viewed here.
I'm afraid that we'd struggle to get our suppliers to accept this as a fault as your connection is currently performing within expectations with no issues found.
A possible cause for this drop could be due to cross talk at the cabinet which is basically interference from other connections.
It may be worth connecting your Fritz!Box 7590 back as you were getting the same speeds before you switched to the Openreach modem?
11-06-2018 10:16 AM - edited 11-06-2018 10:19 AM
What really annoys me about PlusNet these days is the total lack of continuity ![]()
One agent is about to book me an engineer and gets me to wreck my setup to do all these tests only then for another agent to come along only to say it is all within limits and there is no way we will arrange an engineer !!!
This is so frustrating and is not the first time this has happened
I cannot accept there is no fault when my download speed has dropped from 35.8 Mbps down to only 28 Mbps or my sync speed has dropped from 40 Mbps down to only 32 Mbps !
Even the report you just put on the ticket clearly says there is external interference present, source unknown ?
Two reports 1. - How is was 2. - How it is now...
GEA Test Detail
| Circuit ID | NA | Service ID | BBEU04907689 |
| Test Outcome | Pass | ||||
| Test Outcome Code | GTC_FTTC_SERVICE_0000 | ||||
| Description | GEA service test completed and no fault found . | ||||
| Main Fault Location | OK | ||||
| Sync Status | In Sync | ||||
| Downstream Speed | 38.2 Mbps | ||||
| Upstream Speed | 6.0 Mbps | ||||
| Appointment Required | N | ||||
| Fault Report Advised | N | ||||
| NTE Power Status | PowerOn | ||||
| Voice Line Test Result | Pass | ||||
| Bridge Tap | Not Detected | ||||
| Repetitive Electrical Impulse Noise | Not Detected | ||||
| Estimated Line Length In Metres | 983.8 | ||||
| Upstream Rate Assessment | Reasonable | ||||
| Downstream Rate Assessment | Very Good | ||||
| Interference Pattern | Regular Interference Observed on Week Days | ||||
| Service Impact | No Impact Observed | ||||
| Interference Duration Longest Occurrence | From 14:30 to 23:45 | ||||
| Interference Location | Customer Premise | ||||
| Home Wiring Problem | Not Detected | ||||
| Downstream Policing Discard Rate | 0.0 | ||||
| Customer Traffic Level | Upstream and Downstream Traffic Detected | ||||
| Technology | VDSL | ||||
| Profile Name | 0.128M-40M Downstream, Interleaving Low - 0.128M-10M Upstream, Error Protection Off | ||||
| Time Stamp | 2018-05-15T14:45:00 | ||||
| Parameters | MIN | MAX | AVG |
| Down Stream Line Rate | 36.3 Mbps | 40.0 Mbps | 39.3 Mbps |
| Up Stream Line Rate | 5.9 Mbps | 5.9 Mbps | 5.9 Mbps |
| Up Time | 866.0 Sec | 900.0 Sec | 899.9 Sec |
| Retrains | 0.0 | 1.0 | 0.0 |
| Current and Last 15 Minute Bin Performance | ||
| Parameters | Last Traffic Count(Upto 15 mins) | Current Traffic Count(Upto 15 mins) |
| Start Time Stamp | 2018-05-23T12:12:51Z | 2018-05-23T12:27:51Z |
| Ingress Code Violation | 1 | 0 |
| Egress Code Violation | 0 | 0 |
| Errored Seconds | 0 | 0 |
| Severely Errored Seconds | 0 | 0 |
| Unavailable Seconds | 0 | 0 |
Now how it is...…..
GEA Test Detail
| Downstream Speed | 31.0 Mbps | ||||
| Upstream Speed | 7.1 Mbps | ||||
| Radio Frequency Ingress | Not Detected | ||||
| Cross Talk | Not Detected | ||||
| Estimated Line Length In Metres | 979.0 | ||||
| Upstream Rate Assessment | Very Good | ||||
| Downstream Rate Assessment | Reasonable | ||||
| Interference Pattern | Regular Interference Observed on Sundays | ||||
| Service Impact | Retrains Observed | ||||
| Interference Duration Longest Occurrence | No Timing Information | ||||
| Interference Location | Unknown | ||||
| Profile Name | 0.128M-35M Downstream, Retransmission High - 0.128M-10M Upstream, Error Protection Off | ||||
| Time Stamp | 2018-05-29T08:30:00 | ||||
| Down Stream Line Rate | 32.3 Mbps | 35.0 Mbps | 34.1 Mbps |
| Up Stream Line Rate | 5.9 Mbps | 7.1 Mbps | 6.1 Mbps |
| Up Time | 0.0 Sec | 900.0 Sec | 891.5 Sec |
| Retrains | 0.0 | 7.0 | 0.0 |
| Start Time Stamp | 2018-06-11T06:59:48Z | 2018-06-11T07:14:48Z |
| Ingress Code Violation | 0 | 0 |
Just saying it is within limits is a cheap shot and an insulting attempt to get out of having to do anything !
11-06-2018 10:28 AM
Sorry to hear that.
Unfortunately your speed estimates have dropped between my colleague's response and my last response.
These figures are what we'd go by when raising a speed fault to our suppliers.
We can't raise a fault based solely on the possible interference the tests have potentially found I'm afraid.
Whilst we shouldn't book an engineer visit as your speeds are within expectations I will be happy to but if there's no fault found on the Openreach network there may be a call-out charge.
Ideally this is something we'd like to avoid as we'd pass on to you part of the charge we receive from our suppliers if an appointment is chargeable.
Let us know if you would like to go ahead.
11-06-2018 5:57 PM - edited 11-06-2018 6:06 PM
In the Think Broadband graph below, up until 12pm I was using my old BT Openreach modem and after the 12pm red bar I went back to my Fritz!Box 7590 and you can just see a bit of red at the top ?
So would anyone like o comment or say it is not as good as the bog standard modem and the possible cause of some or all of my issues ?
11-06-2018 6:17 PM
It does look like there may be something not quite right with your own modem.
Perhaps one of the community may be able to offer more advice into this.
18-06-2018 1:38 PM
Well despite what one PN agent thought, another agent thought a visit from a BT Openreach engineer was required.
Not sure exactly what else he did, 4 days ago, other than checking the line, but I'm back up to 35Mbps Download, 40Mbps Sync, 9db SNR and no CRC errors to speak of - so let's hope it now stays back up here where it use to be ![]()
He did say there was a lot of Aluminium between me and the cabinet, had it been copper he would have expected 38Mbps easily.
So no point in me ever thinking of upgrading to 80/20 although if FTTP was ever rolled out to my post code, that would be nice.
27-07-2018 9:33 AM - edited 27-07-2018 9:36 AM
So a month on from the BT Engineer's visit and my download speed has remained fairly steady at around 33 Mbps, not quite the 35 Mbps I had before all the issues, but close enough
and far better than the 28 Mbps PN was originally saying was acceptable !
So I was genuinely surprised when I checked today only to find that I have been downloading all this week at 37.1 Mbps !!! ![]()
I have never downloaded that quickly since I was on the up to 80 Mbps trial.
Let's hope that it now stays up at this level and many thanks to the PN agent that concluded there was an issue worth investigating after all. ![]()
http://www.speedtest.net/results?sh=5aefd496d27910cee672e5240878a4b4
27-07-2018 1:05 PM
Glad to hear your speeds have improved!
Let us know if you need any further help.
- « Previous
- Next »
- Full Fibre
