For those on FTTP - which speed is best?
isdoo
Re: For those on FTTP - which speed is best?
I can't see them selling the 500mb package if you will not meet the 275mb minimum speed as you would have a get out of the contract etc.
SpendLessTime
Fixes: 86
An upgrade would cause parts of the systems which control your speed to be amended to suit the new limits. This may have the effect of removing whatever is causing the current product not to run at its rated speed. Or it may not.
pjmarsh
Fixes: 23
I'd say probably no, but not in a way that would get you out of your contract.  I can think of a few reasons why you wouldn't be able to get the full speed, and all but 2 of them wouldn't be Plusnet/Openreach related.
The two that might would be down to either equipment on the Openreach network that isn't working well or the equipment hitting their capacity.  Both of these Openreach should be able to resolve.
The rest of the many reasons would be down to your setup and equipment.  For example, I can only hit about 300Mb on my FF900 from my very high spec work laptop, but can from my much lower powered, and fairly old personal laptop.  The reason being, my work laptop proxies all traffic through other services, which limit the speed quite a bit.
Someone else has replied whilst I've been typing this, and the speed profile could be set incorrectly in the Openreach systems, though that should be easier enough for them to check.  It's not something I've heard happen before, but its possible with a relatively low number of people on the technology that it's currently a rare occurrence.
