Finding out what Openreach are going to do
- Full Fibre
- Re: Finding out what Openreach are going to do
- « Previous
- 1
- 2
- Next »
19-12-2012 10:07 AM
From my conversations with BT, people in fibre areas would either get FTTP or an upgraded VDSL DSLAM for FTTC, not both. FTTP bypasses the cabinet and runs straight from the exchange so there is no need to do anything with the old cabinet (fibre supports voice/data and more).
This is my cabinet - http://maps.google.co.uk/maps?q=newport+road,+willen&hl=en&ll=52.062683,-0.721815&spn=0.005323,0.016...
Yet they have had FTTP here for over two years.
I'm pretty sure BT install FTTP overhead via poles. This is probably the preferred method of installing it as you don't encounter problems liked blocked ducts. It's also one reason why so many people in Japan have FTTP - everything is overhead there.
dick:quote
dick:quote
Message 16 of 20
(2,167 Views)
19-12-2012 11:20 AM
good to hear FTTP by poles is a viable thing
it's 'Superfast Cornwall' who've told me my CAB means connection will be via FTTP
not sure about "FTTP bypasses the cabinet and runs straight from the exchange" - from what I hear there is a very different thing for connection directly to the exchange, still very much on trial
Message 17 of 20
(2,167 Views)
19-12-2012 12:14 PM
FTTP can be via pole or underground. The UK currently has rules preventing new work above ground (without good reason, anyway), so you can assume that poles will be done on a like-for-like basis.
I've attached an architecture picture for FTTP. As you can see, FTTP *does* bypass the cabinet - but doesn't replace it with fibre direct from the exchange.
The aggregation nodes & splitters replace the job of today's cabinet, but they do it all hidden underground.
Plusnet Customer
Using FTTC since 2011. Currently on 80/20 Unlimited Fibre Extra.
Message 18 of 20
(2,167 Views)
19-12-2012 12:21 PM
And the same kind of picture for FTTP-on-demand.
Here there's a difference in the way they use the splitter(s).
Plusnet Customer
Message 19 of 20
(2,167 Views)
19-12-2012 1:12 PM
thanks for those WWWombat, helps to have an idea of what they're up to
Message 20 of 20
(2,167 Views)
- « Previous
- 1
- 2
- Next »
- Full Fibre
