Fibre to the property trial
jerv86
Ive been sent to this forum to get details on a 'Fibre to the property trial' which is available in my area as FTTC currently isnt, Anyone know how i can apply? not sure who i'm supposed to be talking too at this point.
Cheers
2 REPLIES 2
SpendLessTime
Fixes: 86
Re: Fibre to the property trial
Welcome to the forums.
First you must be an existing Plusnet broadband customer or join on ADSL.
Then, check with BT if you are able to get FTTP using the BT Broadband checker at http://www.dslchecker.bt.com/adsl/adslchecker.welcome?
The results will need to look like this
If the first line of the "Featured Products" says "WBC FTTP" then you can apply for the trial at http://trials.plus.net/
Another way is to go to the BT Retail website and see if you can buy Infinity 4 from them (FTTP at 330Mbps download). If you can then you can also apply to join the Plusnet trial or use BT or even Zen (the latter 2 offer FTTP as a product not just a trial)
Finally Plusnet only offer 2 speeds for FTTP, 40Mbps down/2Mbps up or 80Mbps down/20Mbps up. Use BT if you want faster.
If coming across from BT, here is a thread which may answer your queries
BT to Plusnet FTTP Migration Thread
HarryB
Fixes: 256
Welcome to the community forums @jerv86
There's not really much I can say further to what @SpendLessTime has advised, but please do let us know if you have any other questions.
 Harry Beesley
