Fibre: master socket question
- Full Fibre
- Fibre: master socket question
28-06-2011 11:01 PM
Quote 14. I don't want to or can't use the master socket
If your master socket isn't in a handy place (e.g. if there are no nearby power points, or it's in a garage or attic), the engineer can fit a data extension cable. This will let you install the fibre modem up to 30 metres away from your master socket. If you're thinking about this, try to pick the new location before the engineer arrives.
We are about to move into our new build which has sockets in all the rooms.
Surely there's no difference to plugging into a non master socket then plugging into a 30m ext cable which is connected to a master socket?
FYI, I've looked at the sockets and none of them appear to be a master, does the BT engineer replace a particular socket for a master?
Re: Fibre: master socket question
29-06-2011 10:04 AM
However, and the FAQ may not mention this, BT can convert an existing extension socket into a new master socket*. So it looks like you are spoiled for choice!
* there may be some restrictions, depending on how your extensions are wired.
29-06-2011 12:04 PM
Quote from: AxeMurderer However, and the FAQ may not mention this, BT can convert an existing extension socket into a new master socket*. So it looks like you are spoiled for choice!
They can't or should not be doing this as the master socket has to be the one that the external cable is connected to.
29-06-2011 2:05 PM
29-06-2011 3:19 PM
Quote from: Adam1V Surely there's no difference to plugging into a non master socket then plugging into a 30m ext cable which is connected to a master socket?
Extension cable is different spec to normal house telephone extension wiring also, I believe broadband would be split away from voice band at the master socket so 30m extension is only carrying broadband.
29-06-2011 6:11 PM
I've just realised I have 2 Ethernet points next to each bt socket anyway so worst case is I'll still take Ethernet back to my patch panel? But it would just be nicer to store the modem/router out the way a bit
29-06-2011 9:50 PM
If that is the case, then I'd *also* have expected:
a) The master socket to be at the patch panel
b) All the secondaries to be direct links back to the patch panel, as opposed to the more normal daisy-chaining.
OK, the last one might not have happened, but there is a chance that it is wired identically to the ethernet sockets (ie Cat5 cable). After all, a house posh enough to have a phone socket and 2 ethernet sockets in every room, is one that will have made allowance for a patch panel and perhaps multiple phone lines and extensions (or even a small PABX).
Using FTTC since 2011. Currently on 80/20 Unlimited Fibre Extra.
30-06-2011 4:10 AM
Quote from: AxeMurderer Yes they can. They have done in my house. The old rules may have changed.
From your description in another thread I would say it was a bodge.
30-06-2011 9:19 AM
Slightly more on-topic, I did some digging around yesterday and found that BT really can and will replace an existing extension socket with a new master, provided that the extension socket is directly wired to the original master. So if you have a long chain of extensions they can only swap with the first one. If you have several extensions directly wired to the original master socket then they will replace any one of them. The source for this was comments by BT engineers on one of their public forums.
30-06-2011 9:40 AM
Quote from: WWWombat If that is the case, then I'd *also* have expected:
Depends very much on how flexible the builders are...we had CAT5 wiring added to an estate build house 10 years ago...the builders didn't understand what had to be done at all...
In our case the BT master socket is on the ground floor inside directly opposite to where the BT cable appears above ground outside the house. There are also two mains sockets here and 4 CAT5 links to a patch panel in the loft.
Most other rooms then have two CAT5 outlets that also go back to the patch panel. Now with FTTC I have the BT modem right next to the master socket and feed Ethernet upstairs using 1 of the CAT5 links. On the phone side I adapt
the BT line socket to RJ45 with a "special" cable and again feed to the patch panel as CAT5. On the patch panel I have several "parallels" so the phone CAT5 plugs in to one of these and then gets patched down to rooms as required. In
each room I then use a standard RJ45 to BT line socket secondary adapter.
30-06-2011 11:25 AM
Quote from: AxeMurderer Slightly more on-topic, I did some digging around yesterday and found that BT really can and will replace an existing extension socket with a new master, provided that the extension socket is directly wired to the original master. So if you have a long chain of extensions they can only swap with the first one. If you have several extensions directly wired to the original master socket then they will replace any one of them. The source for this was comments by BT engineers on one of their public forums.
Yes, the cable between the old master socket or a junction box has to be a direct feed to the new position of the master socket. What you described in a previous thread was that they used your existing extension cable and that this cable was carrying both the feed to the new master socket and turning the old master socket into an extension socket, this is a bodge.
30-06-2011 11:31 AM
30-06-2011 3:08 PM
This is a bodge only in as far as BT incorporated a not very highly rated, but actually not performance affecting, cable into 'their' part of the system. Although it has now mysteriously been replaced by a cable that is at least as good as they could possibly want.
It remains the case that BT can and will convert an existing extension socket into a new master socket, provided that it is directly wired to the original master socket. And this is very very useful as it solves a lot of potential fibre installation issues. For example, it would be pretty easy to arrange for an extension socket to be exactly where you want the new master socket/fibre modem to be, before BT arrive...
30-06-2011 7:59 PM
I'm probably quite happy that the FTTC is on the other line - which just comes through the wall, with no extension wiring to be getting in the way...
30-06-2011 9:31 PM
- Full Fibre
