Fibre broadband speed low
- Full Fibre
- Re: Fibre broadband speed low
25-02-2022 7:01 PM
We upgraded recently to Fibre and the change over happened on the 17th Feb.
The speed we are getting isn't any better than when we were on standard broadband. On occasion it is worse. Plusnet have said our guaranteed download would be around 29.2MB. We are getting no where near that.
What can I do about this?
25-02-2022 7:19 PM
@lisa79 No doubt the Help Team will pick this up, but if you want help from the Community, we need a little more information (as does the Help Team).
For Community members to be able to help, information from these two sites, as screenshots:-
BT Broadband(obscuring your phone number) and BTW Performance Tester - Over a wired (ethernet) connection, please report the 'ADDITIONAL DIAGNOSTICS', and sight of the HELP DESK tab from your Hub would be a start.
26-02-2022 2:02 PM
Hi
I've attached the 2 images.
My welcome email stated the below - Unlimited Fibre has an average speed of 36Mb download and 9Mb upload.
At peak times, we estimate that you'll get the following speeds on your line:
Download: 38 - 40Mb
Upload: 8 - 10Mb
Minimum Guaranteed Speed: 29.2Mb
Your Minimum Guaranteed Speed is an important number, find out more about what it means in our guide.
Here are some additional off-peak speed estimates for your line:
Maximum download speed: 40Mb, Minimum upload speed: 8Mb, Maximum upload speed: 10Mb
26-02-2022 2:03 PM
Here is the other file.
26-02-2022 2:09 PM - edited 26-02-2022 2:10 PM
26-02-2022 2:14 PM
Thanks, I did wonder if we hadn't been switched over yet.
It was suppose to happen on the 11th Feb and in a post I put on the forum chasing up my new hub delivery I was told by a Plusnet employee the date had changed to the 17th Feb.
Guessing it still hasn't happened yet for some reason.
Not very good communication.
26-02-2022 3:07 PM
With luck, one of the CS staff will come along and provide an update.
26-02-2022 5:16 PM
Hello @lisa79
Thanks a lot for getting in touch and I'm really sorry about this, and for the lack of communication on the account itself. While we did expect the order to upgrade your service to FTTC to complete on 17/02/2022, Openreach did then encounter a delay when "triggering the KCI3" - this basically means completing the order in their internal applications.
I've just had a word with them this afternoon and have been advised that while the physical work has been completed, the notification of completion has not been triggered, which leaves the order open. While the order is open on our suppliers side, the product change remains incomplete on ours, hence you're not getting FTTC speeds yet.
I've been advised that this has been raised with the relevant department on their end, and are expecting the matter to be resolved by 01/03/2022. Please accept our apologies for the inconvenience caused here.
- Full Fibre
