Fibre Trial to start tomorrow
- Full Fibre
- Fibre Trial to start tomorrow
08-02-2011 2:59 PM
My posting on 04/02/2010 Fibre Trial to start next week (not answered)
Have put message earlier on ticket #38597039 which hasn't been responded to.
BT engineer due tomorrow morning but no router delivered as at time of posting this note.
Please give me a call to let me know what is happening.
Regards
Derek
Re: Fibre Trial to start tomorrow
08-02-2011 4:06 PM
Found out that router I was told was posted last Friday wasnt posted till yesterday.
Can now only keep finger crossed that it turns up before engineer leaves tomorrow.
08-02-2011 4:18 PM
08-02-2011 4:20 PM
tnx again
Derek
09-02-2011 8:31 AM
Had BT Openreach engineer call this morning.
He said couldn't carry out fibre connection as had not received router from Plusnet.
He said connection has to be made through router and not direct to computer.
Based on that, rightly or wrongly, I have to assume the info I was given by Plusnet CSC on phone to me yesterday was incorrect.
So, so far have had a WASTED MORNING and an engineer has to come back again.
Thanks Plusnet for not sending router out sooner.
09-02-2011 10:12 AM
So where is it?
09-02-2011 10:53 AM
Found out that order for router was only dealt with at 2347hrs Monday, so very earliest pickup would be Tuesday.
As the install was due Wednesday there was every likelihood it wasnt going to arrive on time.
Plusnet should have been aware and tried to make alternative appointment.
BT Openreach meant to be calling me back later.
Where's the joined up thinking, or am I expecting too much these days.
09-02-2011 1:00 PM
Sure, when they do BT installs they expect a Homehub and are trained on how to install it, but for the rest of us I was under the impression that the engineer disowned that part and simply put the modem in. I know when mine was done (6 months ago) I had to stop him leaving before I'd wired up the router and checked that the whole thing worked because as far as he was concerned if the modem is syncing then that's his job done.
09-02-2011 1:38 PM
09-02-2011 2:41 PM
Quote from: jedi98 Well the Openreach engineer is just plain wrong about having to have a router.
Indeed, if you use monowall or any of the other Linux based firewall systems a PC is your router.
09-02-2011 4:18 PM
I was told by Plusnet that engineer doing installation would ensure all is in order before he leaves as they are paying them enough to do it, so believed engineer doing right thing.
Also concerned to ensure the router is able to connect to the Internet and all phone sockets, master and extensions are working.
Waiting for router to arrive and with a new appointment hopefully all will then go to plan.
Your inputs are much appreciated
Derek
10-02-2011 10:52 PM
10-02-2011 10:57 PM
oakwoods, why buy a new router... (especially when there aren't than many gigabit routers anyway and you don't need one for wireless)... just do as I do and get a gigabit switch (£20->30) and connect router and rest of network to it. FTTC is only 35Mbs tops so you don't need a gigabit port to max it out, a 100Mbs will do just fine.
11-02-2011 12:15 AM
The router turned up lunchtime today, only a day and a half after engineer called.
Have left a note on ticket to that effect, but as usual no response from PN and they supossedly monitoring situation.
Bt were supposed to call me, but haven't.
Will give PN a call in morning.
Peter Vaughan
Yours re gigabit switch will bear that in mind
Derek
11-02-2011 11:13 AM
As expected I had to make a call to PN as had heard nothing from them or BT Openreach.
Got thru to the CSC and as usual they couldn't do anyhthing except pass message on and get someone from FTTC team to call me later today.
There should at least be some provision where if they cant answer a customer query that they put the customer through to more knowledgeable people or is that too simple.
But not holding my breath. Perhaps I'm getting too cynical in my old age.
Still lets see what transpires.
Derek
- Full Fibre
