Fibre Down?
Beanhead
Fibre Down?
Has the net just gone down for anyone please?
I thought it might be just me but I've seen on socials lots of others just after 17:00 this evening.
Anyone else or just me?
4 REPLIES 4
Re: Fibre Down?
You're the first reporting anything here !
You could try typing your phone area code in to the Zen Broadband Status checker, to look for any outages in your area
Re: Fibre Down?
You could try reporting a fault - http://faults.plus.net/
corringham
Seasoned Champion
Fixes: 23
Re: Fibre Down?
Plusnet don't report outages, as their marketeers think it makes them look bad if there is a list of problems that can be seen.
However, most outages are for a single or a small number of connections so it is always worth reporting your outage in case nobody else will do so.l
willcutforth
Fixes: 113
Re: Fibre Down?
@Beanhead please can you private message me your username and I will have a gander for you?
 Will Cutforth
