Fibre Broadband Speed lower than expected
susanjward1947
Hello,
My Fibre Broadband speed is much lower than I expected. Please see below from the Member Centre page;
Your broadband service
  • Product: Unlimited Fibre Extra
  • Estimated Download Range: 48 - 67Mbps
  • Estimated Upload Range: 12 - 18Mbps
  • Minimum Guaranteed Speed: 42.6Mbps
  • Current Line Speed (Download): 27.6Mbps
Speed tests online show approximately 25Mbps, so in the same ball park, give or take.
I tried using the pinned troubleshooting steps, but the btwholesale speed check wasn't available.
I have even had the Master socket replaced with an NTE5C unit, and there has been no change in speeds. The router is connected directly to the VDSL port on the Master socket with no additional filters plugged in.
Below is the connection information from the router.
DSL Line Status
Connection Information
Line state:Connected
Connection time:0 days, 00:24:45
Downstream:28.68 Mbps
Upstream:14.34 Mbps
Can you make any further suggestions please?
Many thanks
Regards
Susan.
2 REPLIES 2
Fixes: 334
Re: Fibre Broadband Speed lower than expected
@susanjward1947 Welcome to the forums. From your post it is obvious you have a major problem. Raise a fault report at: https://faults.plus.net
susanjward1947
@jab1 Many thanks. Will do.
