Fibre Broadband - Slow Broadband
- Full Fibre
- Fibre Broadband - Slow Broadband
19-02-2022 12:54 PM
I joined Plusnet a few months ago and generally the service has been mostly stable and kept a constant speed, however within the last 2 to 3 weeks there has been degradation in the service with running half the speed at just certain parts of the day. Also the service seems to lag on video streaming on anything over 1080p during these period. It seems like my connection is being throttled during these times.
Is there anything I can do to resolve this other than switch providers?
Re: Fibre Broadband - Slow Broadband
19-02-2022 12:58 PM
@welsh_rocker Welcome to the forums. This sounds like an external problem which would possibly follow you to any other ISP.
For Community members to be able to help, information from these two sites, as screenshots:-
BT Broadband(obscuring your phone number) and BTW Performance Tester - Over a wired (ethernet) connection. Please report the 'ADDITIONAL DIAGNOSTICS', and sight of the HELP DESK tab from your Hub would be a start.
20-02-2022 4:54 PM - edited 20-02-2022 4:55 PM
I'm really sorry to see you're having bad speed issues at certain times of the day.
I've tested your line today and the tests are showing your router's getting a good stable speed of around 53mbps.
However, investigating further there's an IP conflict in our systems which may be causing the issue.
I've put some changes through to fix that, could you turn your router off for 20 seconds and then back on again?
Let me know how it goes.
21-02-2022 1:29 PM
Apologies for the delay in getting back to you on this issue. Thank you for checking my line. I can see from your email that my line is now supporting 53mbs. This has dropped dramatically from my previous service providers where my connection supported at last 62mbs. The upstream is the same my line used to support at least 16mb but is down to 13mb.
21-02-2022 4:04 PM
I think it's hard to compare with what you got from your previous provider as speeds can change over time, based on the infrastructure. Our suppliers expectations for your line shown Here are between 44.6mbps 64.1mbps, so unless there are other issues, I'm afraid they wouldn't investigate further unfortunately.
- Full Fibre
