Fastest achievable WiFi speed on the Hub Two router
- Full Fibre
- Fastest achievable WiFi speed on the Hub Two route...
14-12-2025 1:37 PM
Hi. I'm currently on the 300Mb package which finishes in Feb. It's fast enough for our needs but if I was to upgrade am I right in saying that the Hub Two tops out at about 433Mb?
Re: Fastest achievable WiFi speed on the Hub Two router
14-12-2025 1:46 PM
@Megaafc1 that's about right. The Hub 2 is only wifi5 capable. I used to use a wifi5 router (not a Hub 2) and it limited my wifi speed on my laptop to about 450Mb.
As an example of what is possible, my laptop is wifi6 capable and changing to a wifi6 capable router I can now get around 750Mb. Do I notice any difference in reality, well not really!
14-12-2025 2:11 PM
If you are close enough to exceed 433Mb/s on half duplex Wi-Fi you are close enough to use a full duplex network cable !
14-12-2025 3:20 PM - edited 14-12-2025 3:26 PM
Uh?
What "speed" are we talking about here? It's possible I am misunderstanding something...
I use a standard PN Hub 2 router on 5GHz Wi-Fi only, and a little dual band TP-Link Archer AC1300 Mini Wireless USB adaptor. From the router logs the Wi-Fi *connection* is shown at various speeds - but they are all over 433Mb(ps). Here I mean link connection speed, not download speed. As I am on 150Mbps FF I clearly can't stress the Wi-Fi data rate.
Here are a few samples from the Hub 2 router Event log:
11:55:48, 14 Dec. 5G Client associate from 60:**:**:**:**:28 (IP=192.168.1.132) RSSI=-54, Rate=585Mbps, host Lizard
12:32:24, 13 Dec. 5G Client associate from 60:**:**:**:**:28 (IP=192.168.1.132) RSSI=-49, Rate=650Mbps, host Lizard
16:13:30, 12 Dec. 5G Client associate from 60:**:**:**:**:28 (IP=192.168.1.132) RSSI=-49, Rate=585Mbps, host Lizard
12:50:49, 11 Dec. 5G Client associate from 60:**:**:**:**:28 (IP=192.168.1.132) RSSI=-49, Rate=702Mbps, host Lizard
22:43:25, 10 Dec. 5G Client associate from 60:**:**:**:**:28 (IP=192.168.1.132) RSSI=-47, Rate=780Mbps, host Lizard
This one takes the biscuit - but why is the host name not shown? In too much of a hurry? 🙂
21:06:28, 10 Dec. 5G Client associate from 60:**:**:**:**:28 (IP=192.168.1.132) RSSI=-50, Rate=866Mbps, host
14-12-2025 3:29 PM
14-12-2025 3:36 PM
14-12-2025 3:53 PM
I'm talking throughput.
a month ago - last edited a month ago
- Full Fibre
