FTTP trial
Ciaranmck
FTTP trial
FTTP is now available for my home. I am currently not a plusnet BroadBand customer but was thinking of moving. Is there a time limit of how long to wait for trial?
4 REPLIES 4
Aspiring Hero
Fixes: 33
Re: FTTP trial
What does the DSL Checker say for your line?
http://www.dslchecker.bt.com/adsl/adslchecker.welcome
You need to be a PlusNet customer before you apply for the Trial. After that it's basically however long the wait is for an Engineer to be available.
Ciaranmck
Re: FTTP trial
See screenshot attached. I spoke to someone in live chat and was told that FTTP trial was no longer available anywhere. Can someone please clarify?
Strat
Fixes: 565
Re: FTTP trial
The link to the FTTP trial can be found here for use once you are a Plusnet broadband customer.
Aspiring Hero
Fixes: 33
Re: FTTP trial
Because it's a Trial the PlusNet FTTP service is not integrated with their back office systems. Call and Live Chat staff tend to know little if anything about FTTP. If you sign up you can't get PlusNet TV but you can get the BT Sport App.
This is the only place for support. Hopefully a FTTP trained staff member will pick this thread up and advise on your options.
If you do get FTTP then the DSL results are showing it's a "1 stage" install which basically means its should be done on one visit. However, your Under Ground duct has not been evaluated so there's always the possibility of a blockage or some other problem running the fibre.
