FTTP swap over
cbcadmin
FTTP swap over
I am transferring to Plusnet FTTP from Vodafone FTTP.
I understood that an engineer does not visit the property in such situations. However I have just been told by an M.J. Quinn area manager this is not the case. With fibre an enginner will have to visit the property.
This is probably a daft question but does Plusnet get any say in who visits? I assume they just ring Openreach and Openreach contact the cheapest contractor for the area. This is obviously what happened withe initial swap from copper to fibre as it looks as if a drunk installed it!
https://thumbsnap.com/N5yPbrSb
Keef- Sheerness Kent UK - Vodafone FTTP via THG3000 & Three via ZTE MF286D
Previously - NowTV, John Lewis, Shell Energy, Plusnet, Sky, EE, New Call Telecom/Fuelbroadband, Virgin/NTL/Bell Cable, Crosswinds, IC24, FreeOnlineNet, X-Stream, Totalise, Freeserve, Force9, TescoNet, AOL, Freenetname, Pipex, E7
6 REPLIES 6
Fixes: 580
Re: FTTP swap over
Plusnet just place an order (electronically) with OR to supply FTTP. Its up to OR who they use to perform the installation.
You are correct, the Quinn manager is not! If an Openreach ONT exists, then no engineer is required, its just a remote activation.
However, there seems to be some issues with the automated ordering system in that it initially determines that no engineer is required then subsequently specifies an engineer IS required. It seems to require that the automated order is cancelled and a manual one placed for remote activation
cbcadmin
Re: FTTP swap over
God. it sounds if I am in for more “fun” due to flakey systems. Sad
Is there anyway to get an engineer to visit as presumably it makes no odds to Plusnet.
Champnet
Fixes: 21
Re: FTTP swap over
Do Vodaphone use the BT infrastructure ? Round here they use Cityfibre. If not then a whole new installation will be neccessary.
Fixes: 580
Re: FTTP swap over
@Champnet AFAIK they use whichever is available
cbcadmin
Re: FTTP swap over
Mine is certainly BT, but I understand they can use others.
cbcadmin
Re: FTTP swap over
It's BT or nothing round here. Wink
