FTTP download speed just fell off a cliff - anybody else see that?
- Full Fibre
- FTTP download speed just fell off a cliff - anybod...
22-01-2011 10:13 AM
Re: FTTP download speed just fell off a cliff - anybody else see that?
22-01-2011 11:31 AM
22-01-2011 12:55 PM
22-01-2011 3:50 PM
24-01-2011 7:19 PM
24-01-2011 10:43 PM
It tend to drop off the cliff around 9pm each night... should I be seeing SUCH a massive drop? (by morning its back to 16 meg upwards)
Could it be contention on the fibre that goes to the cabinet?
24-01-2011 10:52 PM
Conduct a BT Speedtest during the main brunt of the loss.
Can you indicate when it stars roughly, when it gets worst and ideally, a realistic time it stops.
I do appreciate you may not know if you are not up late enough, but something like the following may assist.
http://www.thinkbroadband.com/tbbmeter.html
26-01-2011 10:20 AM
Will set this up tonight, and leave on.
28-01-2011 3:38 PM
I tried running the www.speedtest.bt.com to find out my IP profile and drew a blank there too "TEST ERROR - unable to run the speed tester. Wait a bit and if you still have problems call your ISP ..." Next step - if it continues much longer - is to raise a ticket with PN.
BTW I tried installing the tbbMeter mentioned above and that failed too "The application failed to initialize ..."
02-02-2011 10:25 PM
- Full Fibre
