FTTP and using my own kit.
Mark_g1
Getting FTTP installed net week, and whilst I ticked the option for the £7 router, i'm hoping I don't need it, and it can be stashed away as a spare.
I'm more than happy with the features and performance of my Draytek box, so my question is going to be:
a)  what box will the engineer fit onto the wall?  some kind of fibre terminator, what is the box's "output"  Is it a PPOE RJ45?
b) can i use my trusty Draytek 2862?
c) if not, is there some suitable Draytek kit I can buy?
Thanks,
2 REPLIES 2
Fixes: 115
Re: FTTP and using my own kit.
@Mark_g1
OpenReach install an Optical Network Terminator (ONT) on your wall. Your equipment conencts vial an Ethernet cable.
https://support.aa.net.uk/Openreach_FTTP_ONT
If your Daytrek supports PPPoE then you can connect it directly.
Fixes: 578
Its an ONT (Optical network termination) , it provides an RJ45 Ethernet connection. It needs mains power and to be within 1m of a socket.
Yes, connect a cat5e ( or better ) cable from the ONT to the WAN2 port on the 2862. Configure WAN2 for PPPoE with your Plusnet credentials and youre good to go.
edit : make sure youve got the Hardware acceleration enabled https://www.draytek.co.uk/support/guides/kb-hardware-acceleration-tips  especially if youre going for > 300Mb FTTP
