FTTP Trial address problem
FIXED- Subscribe to RSS Feed
- Full Fibre
- Re: FTTP Trial address problem
on 02-03-2018 11:24 AM - last edited on 04-03-2018 7:31 AM by Mav
I would like to request to join the FTTP trial but have some issues with my address on the database so I am not sure on the best way to proceed.
When I search on the availability checker with my phone number it says not available. If I search with my postcode my house name is down twice, one is the correct name and the other is a spelling error. FTTP only shows as available for the one with the spelling error.
When I joined PlusNet in January this caused a lot of confusion and took a long time, I signed up with the correct address but turns out the phone line was registered at the incorrect name. Support worked this out and ordered the service at the incorrect address and said they would correct the Openreach database later.
So the problem now seems to be that the phone line is registered at the correct address but the FTTP service only shows available at the incorrect one. So I am not sure what's the best way to go about ordering/fixing this issue. I am happy to order with the incorrect house name if that will work (we get lots of post using it).
Moderator's note by Mike (Mav): Duplicate post released from Spam Filter then removed.
Fixed! Go to the fix.
02-03-2018 12:49 PM
I had a similar issue which was only resolved with the fantastic assistance of @Anonymous . My address was different on the Openreach database to everyone else's databases!
It will likely need a change at Openreach to get it fixed. Mine was fixed in 48 hours, and now just waiting for Openreach to turn up and run my cable.
02-03-2018 1:30 PM
02-03-2018 1:37 PM
Can I send you my PN username and the address details ? this forum username is old and might be linked to an old account, though the address and email should be the same.
02-03-2018 1:40 PM
Hopefully this can be resolved as quickly, I am itching to finally be able to upgrade from ADSL Max to FTTP
02-03-2018 2:19 PM
Sent you a PM with extra details.
07-03-2018 4:28 PM
07-03-2018 6:11 PM
Thanks for the update
13-03-2018 5:24 PM
Hi Gandalf, Just checking in to see if there's been any update from Openreach?
14-03-2018 2:21 PM
14-03-2018 4:25 PM
I don't see any reason why it shouldn't just be a simple case of fixing the address on the database. If they cause any problem then I suggest just ordering FTTP using the address that has the misspelling, after all, we get lots of post that use it without any issue.
15-03-2018 11:06 AM
We had a similar issue with all kinds of organisations with ours. A new driveway was created, linking us to a main road instead of a farm track! Royal Mail issued us with a new postcode without warning, I guess so that their records would show the easier route to access.
Even now, 9 years later, we still have a disparity between all sorts of addresses on varying databases. When a subscription is paid to have access to Royal Mail's records, organisations are meant to update from it,....but it doesn't always happen. PlusNet had our correct address, BT Commercial (our previous phone provider) had our correct address, but BT OpenReach had the old address!
@Anonymous handled our change with BTOR and it went through within 48 hours so you shouldn't have long to wait.
20-03-2018 5:42 PM
Sounds like a nightmare! Good to hear you got it sorted.
We are trying to place an order using the address with the misspelt house name (which has FTTP as available). So fingers crossed it will work.
20-03-2018 5:46 PM
Thanks for placing the order That date is fine. Hopefully it will work
20-03-2018 9:40 PM
- Full Fibre
