FTTP Speeds
jimscott
FTTP Speeds
Please can someone at PlusNet check my speed profile. My Internet has been slowing down over the past few weeks. I have rebooted the router (plusnet issue) but no different.
Running slow on both Wired and Wi-Fi.
Cheers
Jim
2 REPLIES 2
RobPN
Fixes: 13
Re: FTTP Speeds
@jimscott wrote:
What does it say here - Current line speed ?
Fixes: 1,586
Re: FTTP Speeds
Hi Jim. Sorry to hear you're having speed problems.
Everything seems to check out this side. Then again there aren't many diagnostics we can do for FTTP circuits.
Can you run a BT speedtest at http://www.speedtest.btwholesale.com using a wired connection, completing the further diagnostics at the end? This will store the result on the supplier system and will help us in reporting a fault to our suppliers.
