FTTP - Slow download speed
cornwallsurfer
BT tell me my line supports 330 Mb download. I am currently on plusnet FTTP trial with unlimited fibre and speed of up to 76 Mb. Is 39 Mb really the best speed I can expect?!
39 Mb is the fastest I have achieved since activation ten days ago. My download speed is regularly lower than 20 Mb. Surely something is wrong?
22 REPLIES 22
AndyH
Re: FTTP - Slow download speed
Are you running the test wirelessly?
cornwallsurfer
no. ethernet cable 6 feet from router.
AndyH
Can you run the BT Speed Tester http://speedtest.btwholesale.com and run the Further Diagnostics test? Please post the results.
Can you also post your current line speed from here https://portal.plus.net/my.html?action=data_transfer_speed ?
cornwallsurfer
plusnet show line speed as 20Mb. I will complete the bt test tonight. thank you.
Chris
Legend
Fixes: 169
I don't think your account has been set correctly on our side, it's still showing as an ADSL service rather than Fibre. Leave it with me for now and I'll get someone to take a look.
SpendLessTime
Fixes: 86
I've also been having FTTP slow issues since last night at 20:45. Yesterday I couldn't load the BT Wholesale test page at all.
This morning I get a download speed  of 23.17Mbps and upload of 17.13Mbps
and the Plusnet portal details are:
Estimated line speed:
Current line speed:
    77.8 Mb
I am on the 76MB Unlimited FTTP trial.
AndyH
@ georgelnx
Can you try disconnecting/reconnecting from your router to see if that helps? Should be no need to reboot the ONT.
Also, might be worth trying http://www.speedtest.net/ to run your speed test (if you have not tried this already). The BT checker can be a little strange with results at times...
cornwallsurfer
thank you chris.
SpendLessTime
Fixes: 86
@AndyH
Rebooted the router twice last night.
Managed to get through to customer support today and a fault has been raised on the line. We tested connecting the PC to the openreach box and still slow speed.
When the fault was being logged by customer support, the system was insisting that I was an ADSL customer which the CS person found puzzling.
cornwallsurfer
So why is my plusnet profile showing me as being on the Benton exchange in the north east when i am on the newquay exchange in cornwall? And it is showing a telephone number I don't recognise. Still no change in speed. What is going on?!
cornwallsurfer
It looks very much like my line is still restricted to 40Mb!
cornwallsurfer
FAQ
Results Image not loaded
1. Best Effort Test: -provides background information.
Download Speed
42.4 Mbps
0 Mbps 76.8 Mbps
Max Achievable Speed
Download speed achieved during the test was - 42.4 Mbps
For your connection, the acceptable range of speeds is 16 Mbps-76.8 Mbps .
Additional Information:
IP Profile for your line is - 76.8 Mbps
Upload Speed
16.95 Mbps
0 Mbps 20 Mbps
Upload speed achieved during the test was - 16.95Mbps
SuperZoom
This happened to me too - wrong exchange and number, low throughput.
Must be a standard way in which the PlusNet profile systems (whether automated or human) can get their knickers in a twist with FTTP!
Might be something to do with a standard FTTC contract being applied against your account, since there is no standard PlusNet FTTP product (that's the point of the trial) - or that might be a red herring. Although I know what caused them, I never quite figured out whether the billing errors I had were related to the initial profile screwiness or not in terms of internal processes. Both fixed now, though.
Would be interesting to hear how you find ordinary browsing responsiveness once you're up and running properly.
cornwallsurfer
Thank you SuperZoom
I had already decided I better keep a close eye on my plusnet biiling bearing in mind my profile is showing incorrect information!
I will let you know how responsive I find browsing when plusnet sort things out.
