FTTP - Slow download speed
- Full Fibre
- Re: FTTP - Slow download speed
04-12-2013 10:55 PM
BT tell me my line supports 330 Mb download. I am currently on plusnet FTTP trial with unlimited fibre and speed of up to 76 Mb. Is 39 Mb really the best speed I can expect?!
39 Mb is the fastest I have achieved since activation ten days ago. My download speed is regularly lower than 20 Mb. Surely something is wrong?
05-12-2013 5:30 AM
05-12-2013 6:38 AM
05-12-2013 7:41 AM
Can you also post your current line speed from here https://portal.plus.net/my.html?action=data_transfer_speed ?
05-12-2013 9:09 AM
05-12-2013 9:25 AM
05-12-2013 9:26 AM
This morning I get a download speed of 23.17Mbps and upload of 17.13Mbps
and the Plusnet portal details are:
Estimated line speed:
Current line speed:
77.8 Mb
I am on the 76MB Unlimited FTTP trial.
05-12-2013 9:34 AM
Can you try disconnecting/reconnecting from your router to see if that helps? Should be no need to reboot the ONT.
Also, might be worth trying http://www.speedtest.net/ to run your speed test (if you have not tried this already). The BT checker can be a little strange with results at times...
05-12-2013 9:36 AM
05-12-2013 10:04 AM
Rebooted the router twice last night.
Managed to get through to customer support today and a fault has been raised on the line. We tested connecting the PC to the openreach box and still slow speed.
When the fault was being logged by customer support, the system was insisting that I was an ADSL customer which the CS person found puzzling.
05-12-2013 6:14 PM
05-12-2013 6:24 PM
05-12-2013 6:36 PM
FAQ
Results Image not loaded
1. Best Effort Test: -provides background information.
Download Speed
42.4 Mbps
0 Mbps 76.8 Mbps
Max Achievable Speed
Download speed achieved during the test was - 42.4 Mbps
For your connection, the acceptable range of speeds is 16 Mbps-76.8 Mbps .
Additional Information:
IP Profile for your line is - 76.8 Mbps
Upload Speed
16.95 Mbps
0 Mbps 20 Mbps
Upload speed achieved during the test was - 16.95Mbps
05-12-2013 6:38 PM
Must be a standard way in which the PlusNet profile systems (whether automated or human) can get their knickers in a twist with FTTP!
Might be something to do with a standard FTTC contract being applied against your account, since there is no standard PlusNet FTTP product (that's the point of the trial) - or that might be a red herring. Although I know what caused them, I never quite figured out whether the billing errors I had were related to the initial profile screwiness or not in terms of internal processes. Both fixed now, though.
Would be interesting to hear how you find ordinary browsing responsiveness once you're up and running properly.
05-12-2013 6:51 PM
I had already decided I better keep a close eye on my plusnet biiling bearing in mind my profile is showing incorrect information!
I will let you know how responsive I find browsing when plusnet sort things out.
- Full Fibre
