FTTP – Routing via Marseille (mrs20) – 280ms latency to Xbox Cloud / Azure – IP 147.147.130.x
- Full Fibre
- Re: FTTP – Routing via Marseille (mrs20) – 280ms l...
on
14-10-2025
8:37 PM
- last edited on
14-10-2025
8:42 PM
by
Hi Plusnet Team,
Username: [Removed] (FTTP customer, Totnes area)
Since my fibre installation, my connection has consistently been assigned IPs
in the 147.147.130.x range, which appear to geolocate to Edinburgh.
Everything else on the line works perfectly, but Xbox Cloud Gaming has become
unplayable due to extremely high latency (~280 ms). Before fibre, it worked flawlessly.
Traceroute to xbox.com clearly shows my traffic leaving the UK through Marseille (mrs20):
10 be-26-0.ibr01.mrs20.ntwk.msn.net [104.44.29.51] 280 ms
22 20.70.246.20 (xbox.com)
Ping to Google (8.8.8.8) averages 9 ms, confirming the local line and router are fine.
This looks like a routing or Geo-IP issue with the 147.147.130.0/24 block,
causing Microsoft’s network to route my traffic via Azure’s South Europe region
instead of UK South or West Europe.
Steps tried:
• Restarted ONT + router (over 60 minutes powered off) → same IP range
• Changed DNS (1.1.1.1 / 8.8.8.8) → no change
• Tested BoosterX / VPN → only VPNs with UK exit nodes restore normal latency
Could you please escalate this to the **Network Operations Team** to:
1. Move my session to a different BNG/gateway using another IP block, **or**
2. Update the Geo-IP/routing mapping for this range so Azure traffic uses UK edges (lon20 / ams20).
Thank you very much for your help,
Emeric
Moderators Note: Personal information removed
Re: FTTP – Routing via Marseille (mrs20) – 280ms latency to Xbox Cloud / Azure – IP 147.147.130.x
14-10-2025 8:42 PM
Moderators Note
This topic has been moved from Broadband to Full Fibre
15-10-2025 11:55 AM
Thank you for placing the query in the right section of the forum.
I tried again to restart ONT and router here are the results:
Update 15 Oct 2025:
After leaving my ONT and router powered off overnight I received a new IP:
194.75.95.xxx (different block from 147.147.130.x).
Traceroute to xbox.com still shows traffic routed via Marseille (mrs20)
with ~255 ms latency. First MSN hop in London (8 ms), then direct to
be-26-0.ibr01.mrs20.ntwk.msn.net. This confirms the issue is not local
but a Geo-IP / routing problem affecting multiple Plusnet IP ranges.
Could the Network Operations team please review routing to Microsoft Azure
for these prefixes and adjust the BGP / Geo-IP so Xbox traffic enters UK
Azure edges (lon20 / ams20)?
15-10-2025 4:25 PM
Welcome to the Community, @Emeric 😊
I'm keen to see what we can do to get this investigated further, so I've just sent you over a private message so we can grab some more details.
Peter
15-10-2025 7:03 PM
Could this be a related issue?
https://community.plus.net/t5/Broadband/Connection-Issues-for-Gaming/m-p/2024830#M373487
@bobpullen / @dave could this be a peering / routing issue?
16-10-2025 8:49 AM - edited 16-10-2025 8:50 AM
Using nslookup I find there are five xbox.com servers globally.
You would need to use netstat to see which xbox server you are connected to, traceroutes/ping would randomly select one of the five, where as the xbox should select the best server for your locale and device settings.
I pinged the five xbox server as provided by nslookup.
nslookup xbox.com
Addresses:
20.236.44.162
20.70.246.20
20.112.250.133
20.231.239.246
20.76.201.171
ping 20.76.201.171
Reply from 20.76.201.171: bytes=32 time=16ms TTL=112
ping 20.231.239.246
Reply from 20.231.239.246: bytes=32 time=86ms TTL=107
ping 20.112.250.133
Reply from 20.112.250.133: bytes=32 time=107ms TTL=106
ping 20.236.44.162
Reply from 20.236.44.162: bytes=32 time=150ms TTL=106
ping 20.70.246.20
Reply from 20.70.246.20: bytes=32 time=254ms TTL=107
16-10-2025 1:31 PM
Thanks for the suggestion, but the issue isn’t which xbox.com IP responds – it’s that my Azure traffic from Plusnet consistently exits via mrs20 (Marseille) instead of the UK. This has been confirmed on two IP ranges, so it’s likely a routing or Geo-IP mapping issue that only the Network Ops team can correct.
16-10-2025 1:50 PM
The route used could change for a given target IP Address, both IP used are xbox.com
Here's a mtr (traceroute) to 20.70.246.20 I have included the IP Address owners
HOST: wireguard-v Loss% Snt Last Avg Best Wrst StDev
1. AS??? Archer_AX53 0.0% 1 0.5 0.5 0.5 0.5 0.0
2. AS6871 250.core.plus.net 0.0% 1 5.2 5.2 5.2 5.2 0.0
3. AS2856 217.32.25.144 0.0% 1 5.3 5.3 5.3 5.3 0.0
4. AS2856 109.159.255.34 0.0% 1 6.0 6.0 6.0 6.0 0.0
5. AS2856 194.74.16.199 0.0% 1 16.1 16.1 16.1 16.1 0.0
6. AS??? ??? 100.0 1 0.0 0.0 0.0 0.0 0.0
7. AS??? ??? 100.0 1 0.0 0.0 0.0 0.0 0.0
8. AS8075 51.10.14.5 0.0% 1 251.9 251.9 251.9 251.9 0.0
9. AS8075 51.10.23.142 0.0% 1 250.6 250.6 250.6 250.6 0.0
10. AS8075 be-31-0.ibr02.mrs20 0.0% 1 252.5 252.5 252.5 252.5 0.0
11. AS8075 be-14-0.ibr02.sg2.n 0.0% 1 251.5 251.5 251.5 251.5 0.0
12. AS8075 51.10.8.229 0.0% 1 253.2 253.2 253.2 253.2 0.0
13. AS8075 51.10.23.9 0.0% 1 250.6 250.6 250.6 250.6 0.0
14. AS8075 51.10.25.235 0.0% 1 251.4 251.4 251.4 251.4 0.0
15. AS8075 51.10.11.212 0.0% 1 251.9 251.9 251.9 251.9 0.0
16. AS8075 51.10.4.250 0.0% 1 250.1 250.1 250.1 250.1 0.0
17. AS??? ??? 100.0 1 0.0 0.0 0.0 0.0 0.0
18. AS??? ??? 100.0 1 0.0 0.0 0.0 0.0 0.0
19. AS??? ??? 100.0 1 0.0 0.0 0.0 0.0 0.0
20. AS??? ??? 100.0 1 0.0 0.0 0.0 0.0 0.0
21. AS8075 20.70.246.20 0.0% 1 251.2 251.2 251.2 251.2 0.0
Here's a mtr to 20.76.201.171
2. AS6871 250.core.plus.net 0.0% 1 5.1 5.1 5.1 5.1 0.0
5. AS2856 peer3-et3-1-1.redbu 0.0% 1 5.5 5.5 5.5 5.5 0.0
6. AS8075 ae64-0.lts-96cbe-1a 0.0% 1 24.1 24.1 24.1 24.1 0.0
10. AS??? ??? 100.0 1 0.0 0.0 0.0 0.0 0.0
11. AS??? ??? 100.0 1 0.0 0.0 0.0 0.0 0.0
12. AS8075 104.44.53.84 0.0% 1 13.5 13.5 13.5 13.5 0.0
13. AS??? ??? 100.0 1 0.0 0.0 0.0 0.0 0.0
14. AS??? ??? 100.0 1 0.0 0.0 0.0 0.0 0.0
15. AS??? ??? 100.0 1 0.0 0.0 0.0 0.0 0.0
16. AS??? ??? 100.0 1 0.0 0.0 0.0 0.0 0.0
17. AS8075 20.76.201.171 0.0% 1 15.5 15.5 15.5 15.5 0.0
AS6871 is plusnet
AS2856 is BT
AS8075 is Microsoft Corp.
16-10-2025 2:26 PM
Thanks for running those MTRs — they actually illustrate the issue well.
Your trace to 20.76.201.171 hits UK South (≈ 15 ms), while mine — and your trace to 20.70.246.20 — goes through Marseille (≈ 250 ms).
My Plusnet IP range seems to be tagged for Azure South Europe.
Could the Network Operations team please check the Geo-IP / routing entry for Plusnet prefixes 147.147.130.0/24 and 194.75.95.0/24 so that Microsoft routes them via UK South or West Europe instead?
16-10-2025 3:32 PM
What I'm trying to understand why you using an off region site, a search provides this answer.
The Microsoft IP address 20.70.246.20 is assigned to a region in Australia.
Specifically, the geolocation data points to:
Country: Australia (AU)
State/Region: New South Wales
City: Sydney
This IP address is part of the Microsoft Corporation's network (AS8075) and is commonly associated with the Microsoft Azure cloud platform in the Australia East region.
16-10-2025 4:52 PM
Thanks for checking, but that IP isn’t in Australia.
According to Microsoft’s own published Azure IP ranges, 20.70.240.0/20 belongs to the South Europe region (Marseille).
The traceroutes confirm this — all routes pass through mrs20.ntwk.msn.net, which is Microsoft’s Marseille data centre.
The latency (~250 ms) matches France, not Sydney (which would exceed 350 ms).
This supports the conclusion that my Plusnet IP range is being mapped to Azure’s South Europe region instead of UK South or West Europe, causing the high latency in Xbox Cloud Gaming.
Could this please be reviewed by the Network Operations team?
16-10-2025 5:30 PM
Can you ask for engagement on this thread please (and the linked to one) as this potentially looks like a routing / peering issue requiring big guns attention.
16-10-2025 6:15 PM
while we're waiting for some feedback, are you able to confirm the destination IP Address/s of the cloud server you are connecting to, also can you please share a traceroute ?
17-10-2025 9:44 AM
On it, @Townman
Peter has reached out to the OP to arrange some single user diagnostics and I've flagged the issue internally with our technology team.
James
17-10-2025 9:48 AM
I have an interest in the resolution, can I be kept informed please?
- Full Fibre
