FTTP Router
- Full Fibre
- FTTP Router
FTTP Router
24-01-2016 5:51 PM
Re: FTTP Router
24-01-2016 7:51 PM
I've been going through the FTTP tickets recently, apologies if I have missed yours, would you mind sending me a message with the ticket number and I'll get one out first thing
Re: FTTP Router
24-01-2016 7:59 PM
Quote from: geoffb Is this par for the course?
When I moved to FTTP in December - the agent who did the order had forgotten to place order for router - it took a PM to a certain PN staff member when it was just two days away from internal install.
It finnally arrived as OR technician was doing the installation - talk about just in time !
Re: FTTP Router
24-01-2016 9:07 PM
Re: FTTP Router
25-01-2016 10:03 AM
Re: FTTP Router
26-01-2016 2:11 PM
Am I doing something wrong or do I need a preconfigured router from you guys?
Ticker number 116368828
Kevin
Re: FTTP Router
26-01-2016 2:30 PM
Many thanks
Kevin
Re: FTTP Router
26-01-2016 3:21 PM
Download 2-3mb
Upload 20mb
I should be on a 80 20 service
I'm sat here with engineer and he's spoke with bt wholesale and checked the radius is set up correctly and can confirm it is set at 80 20... bt are saying that only plusnet can be throttling the line now?
Thanks again
Kevin
Re: FTTP Router
26-01-2016 3:34 PM
Re: FTTP Router
26-01-2016 3:40 PM
Re: FTTP Router
26-01-2016 3:43 PM
Re: FTTP Router
26-01-2016 3:51 PM
New router is also on the way/has been marked to be dispatched (Apologies that it hadn't arrived prior to the install)
Re: FTTP Router
26-01-2016 4:01 PM
Much appreciated
No worries, the new hub 1 looks better than the old one can't wait for it to arrive now..
Thanks for all your help
Re: FTTP Router
12-02-2016 4:47 PM
Quote from: HarryB I'll get a router out to you ASAP and make sure feedback is passed on to the person who initially forgot to send it.
Thanks for your patience.
Thanks Harry, got the router the next day and after some account tweaking now get a good steady service of 48/20. However as I'm paying for 76/20 that's not quite good enough. The reply to my ticket 118809146 suggest I might have a fault as everything is correct at PN's end and I should have a speed of 80. The link they gave to report the fault doesn't work, can you have a look see. Just reset the router but no change.
Re: FTTP Router
17-02-2016 7:52 PM
