FTTP Installed :D but no faster than my ADSL line :(
john99041
Openreach have finally finished my Fibre to the Premises installation!
Connection is working but the speed is no faster than it was with my ADSL line.... Sad still maxing out a download transfer rate of about 1.5mbps (was getting 1.7mbps with my ADSL)
I'm assuming that as its FTTP I should get something very close to the 80/20 connection that was ordered?
Thanks,
Oh and i've disconnected the old ADSL modem and have plugged the laptop directly to the new plusnet modem just incase it was the wifi acting up, made no difference.
2 REPLIES 2
jelv
Fixes: 10
Re: FTTP Installed :D but no faster than my ADSL line :(
What does https://portal.plus.net/my.html?action=stable_rate say for your current line speed? Once that updates you should be flying.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
john99041
Just checked:
Estimated line speed:
13Mb (This may vary between 7.5Mb and 17.5Mb) - Checked on 2013-05-30 21:40:10
Current line speed:
13.1 Mb
I'm guessing the profile is wrong then? is it just a case of waiting for it to change or can I request it to be updated?
Thanks,
