FTTP Fixed IP
Teece
Re: FTTP Fixed IP
@RealAleMadrid not really, just curious.
bobpullen
Fixes: 330
Re: FTTP Fixed IP
With a static IP, you're being tunnelled through our L2TP network I believe, and that will add a small amount of overhead.
Teece
Re: FTTP Fixed IP
Thanks for the explanation Smiley
alungd
Re: FTTP Fixed IP
@bobpullen @Gandalf
Do I need to request the 'fix' for my static IP (lost during FTTC -> FTTP upgrade) or will it return at some point automagically?
Fixes: 1,661
Re: FTTP Fixed IP
@alungd, Done. Well, I've refreshed the full fibre component on your account so your static IP can now be assigned but you'll need to turn your router off and on. Smiley
alungd
Re: FTTP Fixed IP
@Gandalf  Fair play that was quick!
Connection reset and lo and behold my static IP has returned, outstanding service sir Smiley
Fixes: 1,661
Re: FTTP Fixed IP
Excellent! No problem, happy to help sire.
notcloud
Re: FTTP Fixed IP
@bobpullen I installed a brand new pFsense router last night in place of my TP Link, still saying I have a dynamic IP on the PN page but at least it does say I *SHOULD* have a FIP on the add ons page. However even if I feed the IP address into the shops router to create the IPSEC tunnel, it fails to connect. Is there some ports being blocked?
Gotta LOL tho, on the `historic` fixed ip hidden page, it appears I now have 3 entries for fixed IP`s!!
samunderhill
Re: FTTP Fixed IP
How do I go about getting this refresh done on my account please.  I'm in the same boat, no fixed IP after a messy upgrade path to FTTP.
adam945
Fixes: 113
Re: FTTP Fixed IP
Hello @samunderhill, thanks a lot for getting in touch. I've just clicked a few buttons on my end, so give your router a reboot and let me know how you're getting on.
 Adam
 Plusnet Help Team - Leeds
samunderhill
Re: FTTP Fixed IP
@adam945Awesome, all fixed. Thanks.
adam945
Fixes: 113
Re: FTTP Fixed IP
Ah perfect, thanks a lot for letting me know! Smiley
 Adam
bobpullen
Fixes: 330
Re: FTTP Fixed IP
No ports are blocked assuming you do not have the server-side Plusnet firewall enabled on your account.
Mewcenary
Re: FTTP Fixed IP
Hi!  I have a FTTP order in progress (due to be connected next week).  However, I too seem to have lost my static IP on my CURRENT plus.net connection!  It still shows as existing in the plus.net account pages, but it no longer appears on my connection.
Help!
notcloud
Re: FTTP Fixed IP
@bobpullen pFsense box rebooted, in fact powered off, no joy still says dynamic. How about the ONT reboot?
