FTTP Down Speed
- Full Fibre
- FTTP Down Speed
FTTP Down Speed
01-03-2014 5:05 PM
Thanks for any help
Re: FTTP Down Speed
01-03-2014 5:23 PM
Re: FTTP Down Speed
01-03-2014 5:24 PM
Also how long have you had the fttp link? Sometimes Plusnet do not switch your speed profile so you are limited to the download speed you had on ADSL. Check on your profile speed https://portal.plus.net/my.html?action=data_transfer_speed
Raise a support ticket by phone or from the plus.net website if the phone isn't answered within a reasonable time.
Re: FTTP Down Speed
01-03-2014 5:34 PM
I think you may be correct as on that page it says estimated speed 5mb and current 8mb obviously depending on what product i have. But surely if the upload has gone up massively then download should of too, not stayed the same.
I guess i shall have to ring them or will they do it?
Re: FTTP Down Speed
01-03-2014 5:37 PM
Be impatient 🙂
Re: FTTP Down Speed
02-03-2014 5:41 PM
I am also in Cornwall and had FTTP installed on Tuesday this week. The down speed was about 15Mbps to start with and then dropped to 4.5Mbps. I rang PN and was told that for some reason my connection had been changed, they quickly remedied the connection and now I am getting about 20Mbps again. I assume it will climb up to around 30Mbps+ in the next few days.
I have to say that PN have been very good with the whole installation as an engineer failed to turn up twice and it was sorted.
HTH
John in Hayle
Re: FTTP Down Speed
02-03-2014 6:02 PM
Mike in Helston
Re: FTTP Down Speed
03-03-2014 12:37 PM
Quote from: John
John in Hayle
Quote from: teddman ... Restarted my router and am now getting 37mbs down and 22up. PN are generally excellent at sortin anything iv had to throw at them. I too had an engineer fail to appear when we moved in. Anyway. All sorted.
Mike in Helston
If you're both on FTTP via the PlusNet FTTP trial then AFAIK you should have been provisioned on 80Mbs/20Mbs Download/Upload so you should both be getting those speeds not the speeds you have stated which are both well down on 80Mbs.
Re: FTTP Down Speed
03-03-2014 2:12 PM
I have been made aware of some BT users on fttp in Cornwall who are experiencing slow speeds. You might like to read about it at https://community.bt.com/t5/BT-Infinity-Speed-Connection/Cornish-Speeds-dropping-in-the-evenings-and... and then tell Plusnet about it on your support tickets. if you are all experiencing it, then the error is a group error and should be treated as such.
This sounds similar to the issue fttp users including myself have been experiencing since December last year in Milton Keynes.
Re: FTTP Down Speed
03-03-2014 3:05 PM
I signed up for the 38Mbps deal so do not expect the 80Mbps you quoted. However, I was told that it would be 10 days before I got the speeds I signed for but right now its still about 20Mbps and has been that virtually since day one.
Re: FTTP Down Speed
03-03-2014 6:46 PM
As suggested above if you are not getting near full whack fro the start there's something wrong somewhere
I think this 10 day settling in period is a bit of an "urban myth" especially where fttp is concerned, and often used as an excuse by installation engineers who need to be somewhere else
I had my laptop and router ready next to the ONT as the BT engineer activated it. As soon as the green light appeared and the router established connection I hit "go" on a speedtest - 65/21 on an 80/20 service (ok 15Mb/s light but I didn't wire in the laptop! Next day I wired it in and was up to 72/21)
Re: FTTP Down Speed
03-03-2014 7:46 PM
So like the others have said you should be seeing full speed (at least have a full speed profiile) already.
Re: FTTP Down Speed
04-03-2014 2:50 PM
They are Devolo Duo 500+ and even a few feet apart there is a drop in speed so I don't know what to do now. I tried using wireless but I only get 3.5Mbps with that
Any thoughts?
Re: FTTP Down Speed
04-03-2014 3:06 PM
I am not sure there is much you can do about powerlines - there are some tips here though http://www.smallnetbuilder.com/lanwan/lanwan-basics/31238-slow-homeplug-five-ways-to-boost-powerline...
Re: FTTP Down Speed
04-03-2014 4:27 PM
I have been in touch with Devolo and they reckon one of the adapters may be faulty. (They are the 500 Duo+ models)
I am going to change them for their wireless powerline adapters in the hope that wireless may get me the speed where my home circuit cannot. We'll see.
Thanks again
