[FTTP] Connection drop 1608 hrs, from Bradwell Abbey - OK now
- Full Fibre
- Re: [FTTP] Connection drop 1608 hrs, from Bradwell...
24-02-2016 5:05 PM
Red light on BT Openreach modem at loss-of-service position.
Tried powering off modem for 40 minutes but problem still exists.
Re: [FTTP] Connection drop 1608 hrs, from Bradwell Abbey
24-02-2016 6:29 PM
Re: [FTTP] Connection drop 1608 hrs, from Bradwell Abbey - OK now
24-02-2016 9:14 PM
I have rebooted both the ONT and router several times, but no luck!
Regards
Howard
24-02-2016 11:28 PM
Hopefully the issue is resolved.
Regards
Howard
25-02-2016 12:24 AM
25-02-2016 7:27 AM
I rarely have this problem, but when I do I find that leaving the modem powered off for 20 minutes or more usually sorts the problem out - it causes the card at the local exchange to reboots, I believe. When that doesn't work, I'll try it again for another 20 mins, and if that still doesn't work, I'll leave it powered on and hope someone at Plusnet or BT sorts it out. When the modem is green, then I power the router back on.
25-02-2016 7:52 AM
25-02-2016 9:33 AM
Service has now been resumed now but for how long?
I'm off to work now so I cannot monitor it.
25-02-2016 10:42 AM
I'll check the router log tonight to see if there have been any outages during the day.
Regards
Howard
25-02-2016 7:55 PM
I have rebooted the ONT and router and I have a service again.
I checked the router logs but because I rebooted the router it only has a log from then!
Oh well, I'll be posting here again if I lose the service.
Regards
Howard
- Full Fibre
