FTTP BT Speedtester
- Full Fibre
- Re: FTTP BT Speedtester
FTTP BT Speedtester
30-09-2010 3:03 PM
Could a couple of our FTTP customers give the BT speedtester a try please:
www.speedtester.bt.com
and let me know if it works. If it doesn't can you let me know where it fails (I'm suspecting the page when you put the phone number in).
Thanks,
Plusnet Technology
30-09-2010 4:00 PM
For me it was as you suspected and it fails on the page where you put in your phone number.
It returns an error and to raise it with my ISP.
Paul
30-09-2010 4:07 PM
Plusnet Technology
30-09-2010 4:32 PM
Not sure if you want the actual results as I am assuming you are testing the tool and not the speeds.
Just shout otherwise.
Paul
30-09-2010 5:34 PM
Plusnet Technology
05-10-2010 9:26 PM
I'd be interested to use the BT tester and compare results with speedtest.net. Can you PM me my Service ID, please?
Peter
05-10-2010 9:34 PM
06-10-2010 9:39 PM
I would be interested in using the speedtest as well please if you could send me the sevice ID.
06-10-2010 10:10 PM
thanks, Chris.
07-10-2010 8:56 PM
Plusnet Technology
08-10-2010 10:28 AM
Plusnet Technology
08-10-2010 12:48 PM
I also fancy trying out the BT speedtest
08-10-2010 7:04 PM
09-10-2010 9:24 PM
The BT Speedtester seems to work OK (provided you use the Service ID - Thanks for supplying it)
The only disadvantage seems to be that you can only use it once per hour, so you can't do repeat tests to look at behaviour over short periods of time.
Test result at 17:52 GMT on Saturday 09/10/10:
Download 77.083Mb/s
Upload 12.799 Mb/s
Test result at 20:00 GMT on Saturday 09/10/10:
Download 65.920 Mb/s
Upload 13.366 Mb/s
Peter
11-10-2010 5:33 PM
